Interior lights problem
Old Jul 7, 2013 | 02:16 PM
Vinman72's Avatar
Vinman72
3rd Gear
Default Interior lights problem
At night my interior lights won't turn off and they flash while I'm driving. I thought it might be the door switch but someone told me it might be the light module inside the dash
Old Jul 7, 2013 | 04:28 PM
ch@0s's Avatar
ch@0s
What year is your car? It sounds to me like it could be a switch as well.
Old Jul 7, 2013 | 05:31 PM
Vinman72's Avatar
Vinman72
3rd Gear
It's a 96. The lights use to shut after I turned the car off but now they on
Old Jul 7, 2013 | 10:15 PM
shawn 84&92's Avatar
shawn 84&92
Make sure the key holes on both doors are straight up and down. I know it sounds crazy, but mine were staying on all the time and that was the problem. If they come on while driving, it is a switch. You can shim it out, so they go off.
Shawn
Old Jul 7, 2013 | 10:25 PM
ch@0s's Avatar
ch@0s
Make sure you don't have the light switch dimmer set to ON. This can happen very easily.
Old Jul 8, 2013 | 06:47 AM
Vinman72's Avatar
Vinman72
3rd Gear
Shawn
Thanks I'll try those out first
Old Jul 8, 2013 | 06:55 AM
Vinman72's Avatar
Vinman72
3rd Gear
That was the first thing I checked I purposely turn it on now so I don't have a light show while I'm driving at night I think I'm just going to change the door switch then take it from there
Old Jul 8, 2013 | 01:05 PM
ch@0s's Avatar
ch@0s
When you do there is a trick to replacing it without pulling the door panel.
To Interior lights problem
