Short throw links?
Old Jul 14, 2013 | 04:24 PM
tlfreak's Avatar
tlfreak
Default Short throw links?
I have seen the short throw kits for doug nash 4+3 speeds.By decreasing the length of the shift arms they shorten the length the shifter has to travel but because your losing leverage it must take more effort?Is the increased effort to shift worth the shortened travel and quicker shifts?
Old Jul 14, 2013 | 05:27 PM
pmihaltian's Avatar
pmihaltian
Slingshot
I had the short throw links on my 86 roadster for 20+ years without ANY problems or difficulties. Other than making the shifter movement distance shorter, there was no recognizable difference between the OEM shifter links and the short-throw links.
FWIW,
P.
Old Jul 14, 2013 | 06:00 PM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
That is absolutely correct. You can't have a shorter throw and no increase the effort.
That is a personal decision, and dependent on the type of driving that you do. For general "street driving", It's probably worth it.
Old Jul 14, 2013 | 07:25 PM
vetteoz's Avatar
vetteoz
It is if you take into account not smacking the radio on power shifts
Old Jul 14, 2013 | 08:54 PM
Deepa's Avatar
Deepa
FWIW...
Not a 4+3 but just installed a ZFDoc short throw shifter for my 91/ZF6 and it is absolutely one of the best modifications I have made to this car.
Mike
Old Jul 15, 2013 | 12:59 PM
mtwoolford's Avatar
mtwoolford
Originally Posted by Deepa
FWIW...
Mike
plus having the whole shifter assembly rebuilt at the same time
Old Jul 15, 2013 | 01:15 PM
cv67's Avatar
cv67
St. Jude Donor '05
Any increase is hardly noticeable I wont own a stick without a short throw. If yours is like the muncie make sure the bushings are good and linkage adjusted mint. Youll love it.
Old Jul 15, 2013 | 04:02 PM
tlfreak's Avatar
tlfreak
thanks
Old Jul 17, 2013 | 12:16 AM
powerpigz-51's Avatar
powerpigz-51
I have the short throw on the 4+3, I wish it was even shorter. The linkages do need adjusting after installation, a pain, but doable.
Old Jul 18, 2013 | 12:33 PM
DanZ51's Avatar
DanZ51
I had the "short throw" when I still had the 4+3. Easy to install. You do have to re-align the shifter though. It's easier than the FSM says, you don't to use an alignment pin. Just take off the console lid and sight down the shifter base. You can see the alignment notches. Make your adjustments on the linkage (back under the car). After a couple of tries (auto gynmnastics) it will be sight-aligned
To Short throw links?
