L98 Engine Won't Start
Old Jul 28, 2013 | 09:24 PM
  #41
aklim's Avatar
aklim
Originally Posted by MrWillys
How will this prove it's the diaphragm if the leak is the injectors?
We should move step by step. If the pressure holds, the regulator is bad since it bleeds off the pressure back to the tank. If it doesn't hold, the pressure has to go somewhere so it is probably the injectors.
Old Jul 29, 2013 | 08:09 AM
  #42
FranksRedC4's Avatar
FranksRedC4
Your problem started by adjusting the timing ? Turn it back to where you started and see if it runs.
Old Jul 29, 2013 | 08:14 AM
  #43
Bredd1's Avatar
Bredd1
Timing is not the problem , because The engine will start but will not run or idle without pumping the gas pedal. Besides I adjusted the timing over & over, back & forwards, but same results.
Old Jul 30, 2013 | 09:27 PM
  #44
Bredd1's Avatar
Bredd1
PROBLEM FIXED! The MAF was bad. I replaced it today and the started smoothly mad idled great. Strang thing was that I never got a diagnostic code. I decided to check it after reading the engine start sequence on www.c4vettes.com. Thanks for everyone's help!
