L98 Engine Won't Start
Old Jul 24, 2013 | 01:52 PM
Bredd1's Avatar
Bredd1
Default L98 Engine Won't Start
I've got a 87 L98 engine that won't start. Engine will turn over & plugs are firing but will not start & run. Last thing I did before the problem was adjust the timing on the distributor about 2 degrees but it ran fine after the adjustment. The next day it would not start & run. It's getting fuel to the rails, I measured 40 psi. What could be the issue? Any ideas?
Old Jul 24, 2013 | 02:38 PM
cadmaniac's Avatar
cadmaniac
Timing Chain (not likely). Run a compression test on a cylinder or 2. Air + fuel + spark (at the right time)+ compression should run.
Also (of course) the ECM needs to control ignition timing correctly also. It also controls the Injector Firing. You have batch fire injection so all the injectors should pulse at the same time. I have heard about a "noid" light to help diagnose that, but have never used one myself.
Of course the Factory Service Manual will help you troubleshoot it correctly.
There is lots of help to be had from experts on this forum, also.
Good Luck.
Old Jul 24, 2013 | 03:15 PM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
Is the 4 pin connector at base of dizzy connected and tight ?
Old Jul 24, 2013 | 03:26 PM
MrWillys's Avatar
MrWillys
Get a noid light and see if the injectors are firing first.
You can also follow this flowchart:
http://www.chevythunder.com/ses_chart_a3a.htm
Old Jul 24, 2013 | 03:29 PM
Bredd1's Avatar
Bredd1
Dizzy?
Old Jul 24, 2013 | 03:44 PM
MrWillys's Avatar
MrWillys
Originally Posted by Bredd1
Dizzy?
distributor
Old Jul 24, 2013 | 03:54 PM
ladystoy69's Avatar
ladystoy69
first off there is not enough info or at least not descriptive enough problem diognosis so far to even attempt at a good guess, only a vage guess.
you state turns over and plugs fire...how is this being verified that the plugs are firing? are you physically removing them and cranking engine while plug body is grounded? checking spark on plug wire itself with timing light or other spark testing equipment? or is the engine trying to start(like sputtering, speeding up but just not quite starting?
if spark is truely there and i mean truely firing plugs not just the wires then i would recoment the quickest easiest way to determin if its a fuel problem by getting it to fire by spraying a little start fluid into the plenum area and see if it fires, tries to start or actually start.
also does it smell heavy of fuel when cranking? if so try holding accelerator pedel to floor while cranking to make sure its not flooding itself on trying to start.
basically like i said the description of what its doing and how its acting is just too vague to tell you how to continue to diognose without just telling you to test everything step by step from a flow chart .
Old Jul 24, 2013 | 04:01 PM
Bredd1's Avatar
Bredd1
I verified the spark with a timing light but the engine also tries to start but kind of sputters. I was able to make it start for a few seconds by patting the gas pedal as the engine was being cranked but it would not stay running.
Old Jul 24, 2013 | 04:18 PM
ladystoy69's Avatar
ladystoy69
pull out a plug or 2 and look at them, what do they look like? black? clean white, wet, dry? what do they smell like? fuel or not really anything?
Old Jul 24, 2013 | 05:25 PM
aklim's Avatar
aklim
Shouldn't the timing be 6 degrees and not 2 unless you are like mine and have 0 but compensated in the chip.
Old Jul 24, 2013 | 05:49 PM
MrWillys's Avatar
MrWillys
I read that as he went from 6 to 8? I will reafirm base is 6 degrees + whatever the spark table adds.
Old Jul 24, 2013 | 06:19 PM
Bredd1's Avatar
Bredd1
Ok, I just went through & pulled all the plugs. They were a little foul with soot but not terribly bad, but I went ahead & cleaned them but basically had the same result when I started the engine. I was able to get the engine started & maintain it for a moment by patting the gas pedal but it would immediately die when I stopped patting. Any ideas?
Old Jul 24, 2013 | 06:23 PM
MrWillys's Avatar
MrWillys
I wonder if the iac is stuck closed? Or bad tps? Got scanner? Not reader
Old Jul 24, 2013 | 06:38 PM
Bredd1's Avatar
Bredd1
I only have a code reader but I'm not getting any codes. I would think that if it was the IAC, that I could maintain the engine by holding the throttle. When I hold the throttle, the engine dies. It only try's to keep running when I pat the throttle.
Old Jul 24, 2013 | 07:29 PM
aklim's Avatar
aklim
Could it be a bad IAT that tells the ECM it is stone cold and maybe it needs to dump a bunch more fuel?
Old Jul 24, 2013 | 08:10 PM
Bredd1's Avatar
Bredd1
What is IAT?
Old Jul 24, 2013 | 08:12 PM
MrWillys's Avatar
MrWillys
FYI, Cliff made a comment the other day that kind of surprised me. The only thing in the programming shown as using the IAT is the EGR caveat. If you know of another please point it out.
Your theory would work with the CTS though? Personally, I'd start looking at fuel pressure leak down, and fully functioning TPS
To L98 Engine Won't Start
Old Jul 24, 2013 | 08:13 PM
MrWillys's Avatar
MrWillys
Intake air temp sensor at bottom of plenum.
Old Jul 24, 2013 | 10:43 PM
aklim's Avatar
aklim
I would say it has some effect on the programming but I can't be sure since I haven't hacked it apart but I thought I read somewhere that it does have some effect.
That too could be an issue. He'd have to get a scanner to be reading the values.
Old Jul 24, 2013 | 10:51 PM
kevingib's Avatar
kevingib
Sounds like it is loading up and fuel fouling plugs. I suspect the air reading in the computer is off and it is dumping fuel. Have you considered pulling and cleaning the TB plate also?
