Went the track, something wrong here?
Old Jun 29, 2002 | 12:41 AM
Red91Vette's Avatar
Red91Vette
Default Went the track, something wrong here?
Ok I went to the track about a month ago. I ran a 13.822 @ 99.25 MPH with a 2.059 60ft. Now tonight, I went to race this mustang cobra, first run 14.065 @ 99.74 MPH with a 2.052 60ft. Second run 14.196 @ 98.18 with a 2.079 60ft. Third run 14.048 @ 97.12 with a 2.014 60ft. Does it seem weird that my MPH decreased every run? My times didn't? Is there anything wrong with my car? I don't get this. I know the better 60ft. you get usually the lower MPH you get, but there wasn't to much of a difference with the 60ft. times and the MPH. I know I am running slower then before ( 1 month ago ) because it was hot and humid. I just don't understand, I've never been any slower then 99 MPH, my best MPH before was 101! Can someone please help me here????? :confused: Thanks.
[Modified by Red91Vette, 4:45 AM 6/29/2002]
Old Jun 29, 2002 | 12:46 AM
scorp508's Avatar
scorp508
Heat & Humidity play tricks with a car's power. Was your engine/coolant temp also hotter as you did each run? Did you open the hood and let the car cool down while waiting?
It is possible that the air conditions changed quite a bit while you were there.
Old Jun 29, 2002 | 02:35 AM
Mr Mojo's Avatar
Mr Mojo
Elite Torch Red Member
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
St. Jude Donor '03-'04-'05-'06-'07
Default Re: (scorp508)
Last week, I was running at 100 mph in the early stages, later in the day, I was at 99 mph.
Old Jun 29, 2002 | 02:46 AM
The Example's Avatar
The Example
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
Default Re: Went the track, something wrong here? (Red91Vette)
Yeah, heat can definitely do a number (ha) on your quarter mile times. At the Cruise-In III, I was running consistent 14.3-14.4 runs until about noon. When I started racing again at around 1, I barely ever cracked 14.5.
Old Jun 30, 2002 | 01:04 AM
Red91Vette's Avatar
Red91Vette
I cooled my car down with bags of ice, on the plenum and runners. My temp. was always nice and cold, but I could see my MPH going down somewhat, but 3 MPH!
Old Jun 30, 2002 | 12:05 PM
War Machine's Avatar
War Machine
From: Airport Cruise-in 1 Veteran Airport Cruise-in 2 Veteran
Default Re: (Red91Vette)
:yesnod: The ambient temps play a huge role in how your car runs. Heat will slow you down some, add in some high humidity and it slows even more. My 87 runs between 97mph and 100mph depending on wx conditions.
Old Jul 1, 2002 | 02:48 PM
Red91Vette's Avatar
Red91Vette
Default Re: (War Machine)
My brother (Tpivette89) went too, and his times were .2 tenths slowr but his MPH were only 1 less if that. Mine were 3! and also it ws getting late at night so it got cold and my MPH still went down!
Old Jul 1, 2002 | 03:50 PM
65Z01's Avatar
65Z01
Your trap speed depends mostly on temp & baro, with a little from RH.
The other factor is heat soak, amount of fuel, and any extra weight.
I always weigh the car at Raceway Park and compute crank HP from the trap speed. I use equations (on my site) to normalize both trap speed and ET for baro and temp. Only then can I make valid comparisons from week to week. Even then my trap speed (i.e. HP) varies a little with coolant temp.
Old Jul 1, 2002 | 03:54 PM
Thumper's Avatar
Thumper
I think it was just the heat. Your MPH was pretty close so I don't think there is anything wrong with the car. By the way, did you beat the Cobra?
Old Jul 3, 2002 | 12:24 AM
Red91Vette's Avatar
Red91Vette
Default Re: Went the track, something wrong here? (Thumper)
Yeah I did beat the cobra. He was talkign all kinds of poopie and then when he got down to the track, I got right behind him. He ran a 14.6 then I think a 14.3. But that is the best he is going to get, he doesn't have a clue how to drive stick. When i beat him, he admitted that both my car and my bros were bad butt! :yesnod:
To Went the track, something wrong here?
