lt1 stoped running
Old Aug 22, 2013 | 08:33 PM
corvette1992coupe's Avatar
corvette1992coupe
6th Gear
Default lt1 stoped running
Never had any trouble with car , took of from light went to shift into 3rd engine dieded restarter but wont idle, wont rev up runs real rough. Any ideas where to start ?
Old Aug 22, 2013 | 08:36 PM
R&L's C6's Avatar
R&L's C6
Get a hold of a code reader and see what codes it's throwing.
Old Aug 22, 2013 | 08:37 PM
RicK T's Avatar
RicK T
You posted in the wrong Forum for a 1992 C4 Corvette.
Here is where you need to go. Best of luck.
http://forums.corvetteforum.com/c4-g...discussion-34/
Old Aug 22, 2013 | 09:06 PM
corvette1992coupe
6th Gear
Default lt1 stopped running
yea i know new here, only code is 12 every thing working
Old Aug 22, 2013 | 10:43 PM
strawboss's Avatar
strawboss
Opti spark....
Old Aug 22, 2013 | 10:49 PM
c6z51Ls3m6's Avatar
c6z51Ls3m6
Originally Posted by strawboss
Opti spark....
without a doubt...
Old Aug 22, 2013 | 11:16 PM
4thC4at60's Avatar
4thC4at60
Opti spark....
Originally Posted by c6z51Ls3m6
without a doubt...
Oh, and when you fix the Opti replace the water pump at the same time, it'll be off anyway.....
Old Aug 22, 2013 | 11:51 PM
DAFFYDRUNK's Avatar
DAFFYDRUNK
This might even be the culprit. Water pump bought the dust weep hole dumped coolant all over the opti? I thought the pre 94 were sealed and not vented as well? Not sure how that factors in. I remember replacing the power steerin and water pump in my 96 TA one day but didn't have to replace the opti.
Old Aug 23, 2013 | 09:18 AM
Yellow 2000's Avatar
Yellow 2000
I agree on the water pump and Opti-Spark. It does not like to get wet.
Old Aug 23, 2013 | 09:48 AM
TLS_Addict's Avatar
TLS_Addict
Check a few things. 1. Coil. 2. Fuel filter, 3. Fuel pump. 4. Plugs and wires 5. Opti.
Opti is easy to replace. A couple hours start to finsih.
Old Aug 23, 2013 | 04:43 PM
tenaus's Avatar
tenaus
If you are going to put in a new opti look at the petris vented opti. I put one on my 94 a few weeks ago and the car has never run better. It is very well built.
To lt1 stoped running
