Xfire intake mods
Old Aug 23, 2013 | 12:58 PM
jseremba's Avatar
jseremba
Default Xfire intake mods
Hello,
I have a stock 1984 4 plus three. I purchased a xfire manifold to port, so I can keep from messing up my original intake.
Is porting the point where the runners contact the head enough. I mean are the runners big enough to permit enough air to make a significant increase in performance.
I took a quick look at the renegade and it looks like the runners are larger than the ones on the stock intake. So are the runners on the Renegade larger?
How do I measure the fuel pressure. I know how to measure from the pump. But is there a way to measure and change the pressure from the regulator.
Thank you,
Joe
Old Aug 23, 2013 | 01:01 PM
cv67's Avatar
cv67
St. Jude Donor '05
Porting usually involves going all the way through the GM ports are a little puny. If you can afford the Renegade thats the way to go.
Old Aug 23, 2013 | 02:08 PM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
Renegade is the way to go if you can get one.
The stock CFI runners are so small, you can not hurt anything by porting too much. The more metal you can remove from those runners, the more power the intake will make. If you "vent" it, use a good quality epoxy to repair and it will hold.
FP is the same everywhere in the fuel system from the outlet of the pump, to the regulator (unless you have a major restriction like a kinked line or totally clogged filter). You should be able to "T" in to the feed line anywhere and get a legitimate reading.
Adjust by changing the pre-load on the spring in the fuel pressure regulator.
Old Aug 23, 2013 | 07:17 PM
ex-x-fire's Avatar
ex-x-fire
If your really serious about porting the stock intake it might be a good idea to have someone tig weld some beads on the underside of the intake, the area just before the flange. This will allow you to port more & further in on the floor side.
There's a picture of a cross sectioned cfi intake in my album, the area where I'd add material is below & right of the tape measure. If fact, you could have the whole coolant channel welded closed at both end, add more material to the floor & then port like crazy.
Old Aug 23, 2013 | 10:20 PM
blkvette85's Avatar
blkvette85
Did DCS sell the Renegade design?
http://www.eddiemotorsports.com/prod...old-msren-100/
Old Aug 24, 2013 | 12:50 AM
vetteoz's Avatar
vetteoz
DCS is still showing "TEMPORARILY SOLD OUT " but at $25 more
Old Aug 24, 2013 | 07:52 AM
jseremba's Avatar
jseremba
you read my mind. I was wondering about that just yesterday. Thank you
Old Aug 24, 2013 | 07:56 AM
jseremba's Avatar
jseremba
How do i see these picutres. Thank you
Old Aug 24, 2013 | 09:21 AM
ex-x-fire's Avatar
ex-x-fire
Click on my avatar name, click public profile, & click on engine pictures.
Old Aug 25, 2013 | 08:29 AM
corvettenorway's Avatar
corvettenorway
Originally Posted by jseremba
Hello,
Thank you,
Joe
http://forums.corvetteforum.com/c3-g...re-intake.html
Old Aug 25, 2013 | 08:33 AM
corvettenorway
http://forums.corvetteforum.com/memb...ire-31877.html my pics !!!!!!!!!!!!!!!
Old Aug 26, 2013 | 08:34 PM
jseremba's Avatar
jseremba
Originally Posted by corvettenorway
greta pictures thank you
Do you know how much horsepower the porting gave you
Old Aug 26, 2013 | 08:41 PM
jseremba's Avatar
jseremba
I feel so dumb. How do I find your avatar name. all I see is ex-xfire.
Thank you
Got to tell you. you guys have me really pomped up about doing this
Old Aug 26, 2013 | 08:55 PM
qws's Avatar
qws
A property ported intake can see 25 to 40 HP gains
Old Aug 26, 2013 | 09:34 PM
ex-x-fire's Avatar
ex-x-fire
all I see is ex-xfire.<<<-------Click on this above my avatar picture.
Old Aug 27, 2013 | 12:41 PM
corvettenorway
Old Aug 28, 2013 | 08:14 PM
jseremba's Avatar
jseremba
Being I will have the intake off and they are right there. I was thinking of putting roller lifters. Any opinions out there? I will probably go to roller lifters in the near future.
Oh if I use rollerlifters do I use linked or use the pan that holds the lifters in place.
To Xfire intake mods
Old Aug 28, 2013 | 08:16 PM
jseremba's Avatar
jseremba
Default egr
As far as the EGR goes. I was looking at your pictures. The EGR is still connected, correct? all you did was shorten the channel, correct?
Old Aug 28, 2013 | 08:50 PM
ex-x-fire's Avatar
ex-x-fire
That picture is a xfire intake cut in half to show the small ports & coolant channel that runs under it. It doesn't show the egr channel.
I had my intake extrude honed in '97, I wasn't that impressed with it. It seems like that process makes everything smooth with out a lot of material removal. I would have been better off hand porting it & then sending it out to extrude hone.
I ended up going with a conventional type dual plane intake with a truck tbi unit on it.
Old Aug 28, 2013 | 09:49 PM
1984crossfirefuelie's Avatar
1984crossfirefuelie
This is a good thing now they can ramp up production and all crossfire owners can get there hands on them.
