SESlight
Old Aug 25, 2013 | 04:28 PM
bj9064696vette's Avatar
bj9064696vette
Cruising
Default SESlight
i have a 96 LT1 and the ses light came on the car runs and drives great. Any ideas what could cause this.
Old Aug 25, 2013 | 06:52 PM
eatmydst1234's Avatar
eatmydst1234
Go to autozone, they will scan it free and report back with the code they give you
Old Aug 26, 2013 | 12:22 AM
Cliff Harris's Avatar
Cliff Harris
Or you could look at the codes yourself:
http://forums.corvetteforum.com/c4-t...n-96-cars.html
Old Aug 27, 2013 | 08:46 AM
bj9064696vette
Cruising
I got the code and it said P0400 egr valve not enough flow on egr system. Said could be several things.
Old Aug 27, 2013 | 09:32 PM
Wathen1955's Avatar
Wathen1955
I just finished fixing mine yesterday - same code P0400 EGR issue
You have to take the EGR valve off and clean the small orifice. Here is a pic:
More info here:
http://tech.corvettecentral.com/2012...egr-diagnosis/
Mine did not look as bad as that pic, but the small orifice was plugged. I used a brass wire brush and some brake cleaner. Put the EGR value back on. I reset the code, and drove it for 15 minutes. No more SES light.
Old Aug 28, 2013 | 09:52 AM
bj9064696vette
Cruising
Thanks I will do this before anynparts swap. Thanks for all the info.
Old Aug 31, 2013 | 09:50 AM
bj9064696vette
Cruising
Ok took it off and it was very clean. If I had a vacuum leak would that cause it. I found a vacuum line to the cruise control off. Fixed it and now the cruise works again. So any ideas on why the SES lihht comes on.
To SESlight
