Software/hardware for burning chips
Old Sep 6, 2013 | 05:46 PM
The Bus's Avatar
The Bus
Default Software/hardware for burning chips
I roadrace my "91" C4 and my good friend races his "87". Is there software and hardware still around so we can read our chips and reburn as necessary????
Old Sep 6, 2013 | 06:19 PM
Aardwolf's Avatar
Aardwolf
Yep! I got most of my tuning parts from Moates.net and for software you can use TunerPro R/T for free. The nicest is to get an emulator (Moates Ostrich) so you can make real time changes without burning chips. I found one used on Ebay but that was lucky.
Old Sep 6, 2013 | 06:43 PM
MrWillys's Avatar
MrWillys
See here:
http://www.scotthansen.net/links.html
What I recommend here is the easiest user friendly out there. The free stuff can be very difficult to understand unless you have a programmer mindset.
Old Sep 7, 2013 | 04:54 AM
Cliff Harris's Avatar
Cliff Harris
I paid about $100 for my EPROM programmer from a place in Canada. I have heard recently that Moates is selling one for less. I don't remember if it was $69 or $89.
You'll need some EPROMs. I bought 5 from a vendor on eBay and then found out the seller is only about 5 miles from me.
You will also need a way to erase the EPROMs. Some people put them out in the sun, but that takes quite a while. I bought a small florescent light that is supposed to mount under a cabinet and bought a UV tube online to use in it. I already have a timer from my photography darkroom. I looked into UV LEDs, but they operate at the wrong wavelength and won't work.
Old Sep 7, 2013 | 08:26 AM
vetteoz's Avatar
vetteoz
Only if you are using factory memcals (The old skool way )
Nowadays most use the Moates G1 adapter in their ECM
http://www.moates.net/gp1-package-gm....html?cPath=64
which takes a EEPROM ( Electrically Erasable Programmable Read-Only Memory ) like a 27SF512 which you
can electronically erase and re-program with a chip burner direct from your laptop
http://www.moates.net/burn2-chip-pro....html?cPath=94
Old Sep 7, 2013 | 05:30 PM
MrWillys's Avatar
MrWillys
I gave up ultraviolet light years ago, and strictly use the 27SF512. You have to assign a hex start address of C000 for mass air, and 8000 for speed density.
To Software/hardware for burning chips
