I've noticed that occasionally after idling for a minute I start to get some misfires and surging. I'm thinking 'great, there goes the opti'. I diagnose a little and find this;
I can run my car all damned day and never have a misfire without the A/C. Lately it's been 95+ degrees and humid beyond belief. When I run the A/C for awhile, the misfire returns.
I suspect the accumulator/dryer/receiver/whatever that the brainiacs at GM located directly in front of the cat-scared-of-water opti is dripping condensation and the fan is blowing it directly on the piece of *#@%$.
How many optis are crapping out because of this? Has anybody put a sock on their A/C hardware?
Not very likely ! ! ! ! The 3 small holes (1/16 -1/8 dia) are located on the very bottom of the aluminum plate (housing) of the opti. Moisture has to come UP from there to bother it. A drip would never get there, even behind the wind from fans. . . . . . . Your problem sounds more electrical, possibly the ECM ? ? ? ? :cheers:
Could you be having a voltage drop due to the compressor load on the engine/alternator assemblies. might watch the voltage and possible the amps as the blower motor could be a factor on the alternator if it is drawing excess or higher than normal current. hope it helps, just idea off the top of my head.
I considered that but I'm leaning toward some sort of moisture-related weirdness. The alternator is very new so I don't think I have regulator issues there. The idle goes rough only after the car has been driven for some time with the A/C on and then only when it's been idling for 30 seconds or so. Once the rough idle has started, disengaging the compressor has no effect. Shutting the motor off for 20 minutes will cure it, I'm speculating that heat-soak is drying out whatever is misbehaving. Lower humidity definitely seems to lessen the problem. :confused:
The seal that is inside the opti between the cap and the main unit is known to shrink over time and this can make them victum to moisture.
It would be hard for moisture to be blown into the unit by the fans, the water has to get past the balancer first. Try inspecting your engine when you are having a problem and see if you can see where things are getting wet.
Do you notice it right away or after the build up of condensation?
The opti will either work, or not work. If (enough) moisture is getting into it, it won't run for a few days, not until it dry's out ! ! ! Fact, I've been there. And besides, the condensation from the A/C doesn't drip there, it drips closer to the firewall. :D
