I don't know the fuel pump control well, but I believe that when you turn on the key to the on position, the ECM sends power to Terminal C of the relay. Terminal C is power supply to the relay coil. This closes the connection from Terminal E to Terminal A. Terminal A is the power supply to the fuel pump. This happens for 2 seconds and Terminal C stops getting power from the ECM. The "shot" of gasoline is enough to start the engine, then there is enough oil pressure to close the contacts on the oil pressure switch and continue sending power to the fuel pump via the oil pressure switch.
You are correct. All that is true. But I am not getting any power to the fuse box at the crank, insp and fuel pump so I am trying to find out what happened to my power.
there is no power on the fuses marked Crank, Inst and FP.
You will only have power on the pump fuse if the pump is running or you have jumpered the relay connector.
You say the car starts on the OP switch so you obviously have pump power through the fusible link to the OP switch and at the relay (E )
What you should be concentrating on is why you have no power on C ( that operates the relay ) when the key 1st turned on or when the engine is running
Have you checked the voltage at C with the engine running?
edit.
The pump is running off the OP switch so you can leave the relay disconnected and probe terminal C in the relay connector to ground with the engine running.
It looks to me like you're getting bogged down in chasing electrical questions, without a good understanding of electrical stuff. A really nice feature of the '84 Corvette is that you can watch the fuel injectors work!
I'd suggest a really simple test:
1. Remove the top cover of the air cleaner.
2. Run a jumper wire from +12 v. directly to your fuel pump fuse. You should hear the fuel pump should run.
3. Try starting the car while you are watching the fuel injectors. You should see a continuous spray from both injectors.
4. If you don't see a continuous spray, you probably have low fuel pressure, possible because of a clogged fuel filter or a bad fuel pump, even though the pump is new.
That's mostly correct. The ECM turns on the fuel pump through the fuel pump relay when it sees DRPs (Distributor Reference Pulses), which mean the engine is either cranking or running. Theoretically the oil pressure switch is never needed. It's a backup for the fuel pump relay.
first of all you have clearly assessed my skill with automotive electronics
what I do not understand is why I cannot get the pump to run off terminal G on the ALDL.
I will use your suggestion and thank you
UPDATe
I took a look at diagram 8A and realized that the relays and connector for the fan and the fuel pump were switched.
I then used the Ohm meter and everything is working correctly. I started the car and checked the Fuel pump fuse. It has power. The crank fuse still does not have power.
I could not run the pump through terminal G or by running voltage to the fuel pump fuse.
But the car is starting better, I guess next week I will look at the crank fuse.
Thank yuo all for you patience and assistance.
