'94 Window Motor Test?
Old Oct 5, 2013 | 11:01 AM
Donne Trav's Avatar
Donne Trav
Default '94 Window Motor Test?
Is it necessary to remove "window relay" to test motor? Window switch was been tested — found to be bad —and replaced — drivers side window still not working? Thanks
Old Oct 6, 2013 | 06:59 PM
DUB's Avatar
DUB
I have a test lead that connects directly to the motor for testing when I have an issue with a window motor working. SO...I do not mess with the relay because it is out of the equation due to the factory wiring has been disconnected.
DUB
