Oxygen Sensor
Old Oct 5, 2013 | 01:45 PM
Ricks94vette's Avatar
Ricks94vette
Default Oxygen Sensor
Would anyone have the part #'s for the front and rear Oxygen Sensors for my 1994 6 spd base engine Vette?
Also need a EGR solenoid part #
Also which brand have you had good luck with and which brand would you avoid? So many to choose from
Old Oct 5, 2013 | 02:05 PM
Klyde's Avatar
Klyde
My 96' LT-1 uses ACDelco AFS75 Oxygen Sensors. $24.00 on Amazon. Replaced all four a couple of months ago and they are working just fine. I believe they are four wire. Not sure about whats used on your year. I think you only use three. The front two are used to run the car the rear is for smog testing only.
Old Oct 5, 2013 | 02:18 PM
Ricks94vette
Checked for a pre-smog test and both NOX and HC's are extremely high. Mechanic stated the EGR solenoid was defective and to replace the original O2 sensors as they were emitting a weak signal.
Just want to know if all 4 should be replaced.
Does anyone has know of a website which has a diagram of the exhaust system?
Old Oct 5, 2013 | 02:52 PM
Klyde's Avatar
Klyde
If you are facing a smog test then yes, replace all four. As I stated before the rear two are for testing only. These are the ones they look at to see if your cats are working right. They compare what's going in the front side to what's coming out the rear, New ones in the front will help it adjust your fuel mix better. They should be replaced every 50k miles any ways so you can't lose. I'm still thinking you only have three. OBDI only used two or three and it was 96' when they went OBDII.
Old Oct 6, 2013 | 03:44 PM
Ricks94vette
Thanks Klyde,
Jacked it up this morning to see how many O2 sensors she had. Turns out 2 pre-cat and 1 post cat on the passenger side.
so it's on to order 3 O2 sensors and the EGR vacuum solenoid switch.
Old Oct 19, 2013 | 03:51 PM
Ricks94vette
O2 sensors arrived this week so now the fun begins with installing them.
Does anyone have any tips on this procedure? I've got her on jack stands but it appears very tight to gain access to the connectors.
On one side, I thought of removing the starter to get to the connector but that's one PITA!
Any tips wold be greatly appreciated.
Thanks in advance.
Old Nov 3, 2013 | 07:42 AM
Giamanut's Avatar
Giamanut
Ah the post cat passenger side does absolutely nothing on the 94 model oh wait it does plug the hole.
There is plenty on this. Its there because GM was anticipating the EPA and although it operates, the ecm code does nothing with the info it gets from that 02 sensor. You wont even get a code or light if it is unplugged!
Old Nov 3, 2013 | 07:58 AM
Ricks94vette
Thanks for the info Giamanut,
Ended up having to purchase a 7/8's shorty and had them removed in no time. Amazing what a difference a correct tool can make.
She passed the smog test.
15mph Test: HC measured 55 out of the allowed max of 59, so just barely.
NO-352 out of the max of 541.
25mph Test: HC measured 27 out of the allowed max of 34.
NO - 446 out of the allowed max of 541.
According to the computer on the vehicle her average MPG jumped from 16.3 and is now fluctuating between 19.1 - 20.3 so the 02 sensors definitely needed replacing.
Old Nov 3, 2013 | 09:48 AM
Giamanut's Avatar
Giamanut
Great news gotta get my smog this month engine has less than 100 miles on it.
It's the engine the machine shop said I couldn't build do to line hone but turned out to be BS.
Got a tight timing chain and all is could. now if I could just get the stock cluth to hold the extra power)(*U)(*_)(*_)*!!!!!
Old Nov 3, 2013 | 09:49 AM
Giamanut's Avatar
Giamanut
Mine is also a 94 6sp.
To Oxygen Sensor
