undecided
Old Oct 20, 2013 | 06:10 PM
firsttimechevy's Avatar
firsttimechevy
Dont want to sound dumb im no mech but what is iac
Old Oct 20, 2013 | 06:23 PM
MrWillys's Avatar
MrWillys
Intake air control. It's the 4 wire plug below the throttle body and the passenger side. Using the throttleblade screw (came capped from the factory) make slight adjustments and scan the iac counts. A warm idle should be around 20 to 80 with 40 to 60 being great. There is a minimum idle air adjustment, but the same can be done making slight adjustments and keeping an eye on counts.
Old Oct 20, 2013 | 06:24 PM
l98tpi's Avatar
l98tpi
Max G’s
Originally Posted by GKK
Install, Neither...
The stock throttle body flows enough air to support 400 hp. A 52mm or 58mm throttle body will add nothing to a stock engine.
Exhaust and runners will add maybe, 5hp to your "91" Vette.
I Agee there is no need for a larger throttle body, but disagree that the larger runners and exhaust will only add 5hp. If you replace the runners only with large tube runners and replace the front y pipe with and delete the pre cats and install a low restriction main cat, that will probably add a solid 20-25hp. And one other mod that makes a big difference is underdrive pulleys.
