scanner not reading my car
Old Oct 13, 2013 | 11:32 AM
hitmanpty's Avatar
hitmanpty
Default scanner not reading my car
couple days ago I buy my self a auto x ray xp 240
here is a link on ebay in case you wander
http://www.ebay.com/itm/251310013824...84.m1439.l2649
I have a 1986 vette. also my check ingine light never had work.
when I connect the scanner I get and error. it say. the scanner can not comunicated with the car. read the manual.
I read the manual 20 times allready and the set up is good
why do I get and error. I can not get codes or scan the car
Old Oct 13, 2013 | 12:58 PM
MrWillys's Avatar
MrWillys
When you configured it for a GM 86 did you enter the 8th vin digit?
Old Oct 14, 2013 | 12:44 PM
hitmanpty's Avatar
hitmanpty
yes I did. after that the scanner ask me for the 4 digi also. and after that it ask me if my motor was 5.7. yes or no. I aswer yes
tell me if a bad check engine light volt. will affect the scanner
Old Oct 14, 2013 | 02:26 PM
MrWillys's Avatar
MrWillys
The bulb in the SES light shouldn't affect the scanner. My initial thought would be a bad ecm, or circuit from the ecm to the aldl. see if this helps:
http://www.chevythunder.com/Flow%20c...roubleshooting Flow Chart Pages
Old Oct 14, 2013 | 05:38 PM
hitmanpty's Avatar
hitmanpty
thank you look good
Old Oct 15, 2013 | 08:24 AM
vetteoz's Avatar
vetteoz
Try pulling the codes the factory way
http://www.corvettephotographs.com/c4vettes/codes.htm
If you can get the SES to flash by jumpering the ALDL connector you know the circuit is good (assuming your SES bulb is good ? )
Does the light come on when you 1st turn the Ign on as it should?
Old Oct 15, 2013 | 04:17 PM
hitmanpty's Avatar
hitmanpty
the light never come on. not when I jump the aldl. not when 1st trun the ing.
Like I say I never saw that light come on
Old Oct 16, 2013 | 03:09 AM
vetteoz's Avatar
vetteoz
Have you checked the bulb?
Old Oct 16, 2013 | 08:11 AM
hitmanpty's Avatar
hitmanpty
Not yet, I have to wait into this weekend to work on the car and start doing all those test, including checking the bulb as the first priority
Old Oct 16, 2013 | 03:59 PM
85corvettec4's Avatar
85corvettec4
speaking of this, my scanner asks "yes or no" for 5l5 any idea what that is?
Old Oct 18, 2013 | 10:21 AM
hitmanpty's Avatar
hitmanpty
when I first stat my it ask me for the 8 vin after that ask me for the 4 vin . and then ask me 5.7 yes or no.
I never had that 5l5. no idea my friend. sorry
Old Oct 18, 2013 | 11:32 AM
MrWillys's Avatar
MrWillys
Have you gotten this too work yet? You could try it with another obd1 vehicle to see if maybe it's a problem with the scanner itself?
Old Oct 18, 2013 | 12:03 PM
hitmanpty's Avatar
hitmanpty
my scanner is working fine .
Old Oct 18, 2013 | 07:46 PM
hitmanpty's Avatar
hitmanpty
tomorrow I will try to make some test on the ecm. following this instructions
http://www.chevythunder.com/SES%20chart%20A-1.htm
but Iam a little confuse here. on the chart "where it say:probe ecm term A5 with test light"
my question. sure I use the testlight on the conector or in the ecm it self. can someone just clarify this point to me thanks
Old Oct 18, 2013 | 10:12 PM
Cliff Harris's Avatar
Cliff Harris
That test checks to see if the SES bulb is good.
Disconnect ECM connectors.
Turn on ignition.
Connect terminal A5 in the connector to ground, either with a wire or a test light.
The SES light should come on.
If the SES light does NOT come on then it is probably a bad SES bulb, but could be a problem in the wiring.
I know you have a FSM, so look on page 6E3-A-18.
Last edited by Cliff Harris; Oct 19, 2013 at 11:20 PM. Reason: Added clarification. "A5 in the connector".
Old Oct 19, 2013 | 10:49 AM
hitmanpty's Avatar
hitmanpty
Turn on ignition.
Connect terminal A5 to ground, either with a wire or a test light.
thank you I will
Old Oct 21, 2013 | 10:20 AM
hitmanpty's Avatar
hitmanpty
I did check the ses Light bolt and look ok. I did ground de A5 wire. and nothing happened dont know where to go no
To scanner not reading my car
Old Oct 21, 2013 | 09:48 PM
Cliff Harris
According to the diagram on page 6E3-A-18, the power for the SES bulb comes from the INJ1 fuse. If your engine runs then that fuse must be OK.
I think you should trace out the wire from ECM connector A5 to the SES bulb. It's probably broken or cut or something.
Old Oct 24, 2013 | 10:02 AM
hitmanpty's Avatar
hitmanpty
I will do that today thanks
Old Oct 27, 2013 | 05:57 PM
hitmanpty's Avatar
hitmanpty
after doing more test with terminal A5. I find out that the terminal wire is ok. also at the other end Iam getting good volts with the key to on position.. So I direct my attention to the old information plastic circuit. I find out that is was making some bad contact.
now the ses light is allways on.
I follow the troubleshooting on chart A2 . and it say to get a new prom
I had 2 old ecm at home. so I did the swap and test with the same prom. and no change.
acording to the chart I need a new prom.
i been looking at ebay. and the cost is about $200 that is a big problem.
Is there a way to check the ecm prom to find out if is good or bad????????? I dont like the Idea of getting a new $200 prom. just to find out that make s no diferance
