oil gauge
Old Oct 21, 2013 | 12:06 AM
sweets's Avatar
sweets
Default oil gauge
89 vette oil pressure gauge stuck on 80 psi. I need to know what color code the wires are for the gauge and where they go. has any one had this problem . I have put in a new sending unit. it has been this way sence an engine install.i must have a pinched wire?
Old Oct 21, 2013 | 02:20 AM
vetteoz's Avatar
vetteoz
Org and red wires at the OP switch / sender are the fuel pump wires which leaves the Tan wire? as the gauge wire.
IIRC the 3 wires all come out of the harness in the same location
Old Oct 21, 2013 | 02:27 AM
Cliff Harris's Avatar
Cliff Harris
I believe you get 80 PSI if the connection is OPEN. Could be a problem in the connector or a broken wire.
Old Oct 23, 2013 | 10:46 PM
sweets's Avatar
sweets
I guess ill have to see if the tan wire is in the connection at the insturment panel and maybe try running a bypass wire because I think that it is a broken wire. thanks.
To oil gauge
