Cooling System Bleeder
Old Oct 24, 2013 | 09:12 AM
oloten0's Avatar
oloten0
Default Cooling System Bleeder
When should you bleed the air from the cooling system using the bleeder? When it's warm? Cold?
Old Oct 24, 2013 | 10:05 AM
Kmcoldcars's Avatar
Kmcoldcars
When you are filling it with coolant, which would most likely be cold.
Old Oct 24, 2013 | 12:44 PM
don hall's Avatar
don hall
If you are concerned about your '94 LT1, no bleeding/purging of air is necessary.
To Cooling System Bleeder
