tdc
Old Oct 27, 2013 | 09:26 AM
tideferi's Avatar
tideferi
Default tdc
hi
im looking for tdc on my 350 1984 corvette
i dont have intake and valve cover on it but i already fix the timing cover
when i make a complete turn on the crank..before i come to zero on the balancer. the intake valve are just closing
i do the complete turn...and when i come to zero again its the exhaust valve just closing.
i dont know which one choose and i dont have distributeur on it...
thanks and sorry for my bad english
Old Oct 27, 2013 | 09:37 AM
vetteoz's Avatar
vetteoz
Put finger over # 1 spark plug hole and turn the engine over.
When your finger is blown off the hole, you are TDC on the compression stroke where you want to be.
You may have to wind the engine back a little to line the timing marks up
Old Oct 27, 2013 | 10:00 AM
tideferi's Avatar
tideferi
thanks
Old Oct 27, 2013 | 10:26 AM
cv67's Avatar
cv67
St. Jude Donor '05
if the distributor doesnt drop right in put it where its pointing to #1 on the cap. See if someone can bump the motor over while you put just a slight bit of downward pressure (not always necessary) on the distributor . The oil pump shaft will "catch up" with teh slot on the distributor and drop in or usualy does.
Then rotate over again to double check your work before putting the cap on
Mines stubborn and the oil pump drive leans off to one side "dropping it in is impossible"
Old Oct 27, 2013 | 04:30 PM
Hot Rod Roy's Avatar
Hot Rod Roy
If this is true, your cam timing is wrong or the harmonic damper is damaged. Turn the crankshaft with a socket wrench on the crankshaft center bolt. You should see the exhaust valve move first, then the the intake valve. That's the #6 firing position. Continue turning the crank one revolution to the next timing mark. At that position, you should be able to twist the pushrods for both the intake and the exhaust rocker arms easily with you fingers. That's the #1 firing position.
Old Oct 27, 2013 | 06:23 PM
MrWillys's Avatar
MrWillys
After the intake valve closes bring it to tdc. No finger required. The cylinder fires after it is filled not after it exhausts.
Old Oct 27, 2013 | 06:26 PM
tideferi's Avatar
tideferi
ok hot rod roy
i make one complete turn and i see the exhaust valve moving
i make another complete turn and its the intake valve moving
if i make another turn is repeat exhaust one...another turn intake...another one exhaust etc
To tdc
