SLP ported/siamesed runners?
Old Nov 20, 2013 | 02:47 PM
volkswagens-for-life's Avatar
Default SLP ported/siamesed runners?
Supposedly the previous owner ported my intake and plenum, but its got the stock looking runners on it. I do NOT want to get a short ram or any other kind of ram intake right now because it would require too much additional work, like re-camming my cammed car.
I've heard reports of 20hp from the ported/Siamesed gargantuan runners. I figure that the SLP runners would work good with my current injectors and heads and cam etc.
So whats the deal w/ the SLP ported/siamesed runners... worth the $300 and 20hp (and better power curve)?
Old Nov 20, 2013 | 02:56 PM
vetteoz's Avatar
vetteoz
http://forums.corvetteforum.com/c4-t...re-your-s.html
http://www.thirdgen.org/techboard/po...05-post14.html
Old Nov 20, 2013 | 03:01 PM
I'll read that now thanks
Old Nov 20, 2013 | 06:55 PM
Corvette40's Avatar
Corvette40
Got 247rwhp with custom shorties, custom exhaust and tune. Haven't been on the dyno since I installed mega ported Edelcrock manifold, plenum, SLP runners and port matched 113 stock heads. Did all this for my my new 355 but dropped a spring after a couple of months so I'm re-doing it. It takes a lot of welding and many hours of porting to do it right. I think I have 80+ hours in the runners and manifold. When I finished, the SLP runners weighed half the weight they did when I started.
Old Nov 20, 2013 | 08:14 PM
Did you grind right thru the runner on the top pic ?
Old Nov 21, 2013 | 09:49 AM
Corvette40's Avatar
Corvette40
Broke through in a few places, welded them up and drove on. I found a couple of places on the runners where there were a lot of air pockets in the casting, but they were much better than the Edelcrocks I've seen. I've seen three pairs of Edelcrocks this year alone where the flange that mates to the plenum had to be ground true to seal properly.
Old Nov 21, 2013 | 09:57 AM
Do you know if those large port runners helped you any, in terms of power/tq/mpg/driveability/curve?
Old Nov 21, 2013 | 10:10 AM
TA's Avatar
TA
With your mods, I would think any aftermarket runner/base would yield pretty decent results. However, if you're going through the expense of replacing your runners and intake, it might be beneficial to consider alternative intakes like the superram, miniram, stealth rsm, etc.
On my 383 I have AS&M runners with an accel base. It makes gobs of torque and decent HP (325/450 to the wheels), but I'm fairly sure I'd gain at least 50 HP by switching to another intake.
Old Nov 21, 2013 | 10:24 AM
The problem is I dont want a bigger hood, I dont want to spend $600-1000 for another intake, and then I dont want to re-cam the engine etc for the higher rpm powerband a different intake will achieve.
SLP runners are around $300 brand new and supposedly worth a good 20-30hp. It will shift my power curve up just enough that my supposed current mods (namely cam) will still be in their sweet spot.
Old Nov 21, 2013 | 10:38 AM
cv67's Avatar
cv67
St. Jude Donor '05
If I were you pull the base off and take that sucker til its within its last breath of the casting til youre almost epoxying. wont hurt anything
Remember you have to go ALL the way through the runner necks way down about an in or so in and gets worse from there. It will take a long time but if you can DIY its free power. If you do it right the runners will look more squarish than round anymore
Cut the runners in half go to town on them weld back up. Might wanna jig it up first just in case or set the assy on the bench then - its about volume/dia not a huge entry way
Dont believe 30hp from just bolting those runners on .
Old Nov 21, 2013 | 10:44 AM
^But if you look at the SLP units side by side, even w/ ported STOCK runners to non-ported stock SLP's, the slp's could swallow the stock runners up lol...
Old Nov 21, 2013 | 10:49 AM
cv67's Avatar
cv67
St. Jude Donor '05
No doubt but remember they already probably outflow the stock base even with a little work done. So take the runners farther and butcher the hell out of the base that will be your restriction
Old Nov 21, 2013 | 10:59 AM
Well I suppose that could certainly be a good option to keep me entertained and busy this winter. What do you suggest using for the grinding of the runner?
How important is siamese? I've never done that before.
Old Nov 21, 2013 | 11:32 AM
cumbercr's Avatar
cumbercr
From what we have heard of your build so far, it's very likely your cam is designed for a higher power band. The stock TPI long tube runners are designed for low end torque. Peak HP is around 4800 RPM. In my opinion you have 2 options. You can replace the intake with a shorter runner design and keep the cam you have. Or keep the long tube runners and swap the cam. Raising the band 300 RPM with SLP runners is not going to give you the results you are looking for.
Super Rams and Mini Rams have the same height profile as stock intakes. So there's no need to change the hood.
Old Nov 21, 2013 | 11:36 AM
Take a look at the cam in my sig. Thats what Brian @ TBIchips and me have concluded I'm most likely running based off of how the car runs, idles, the mods it has, what he was told to burn, and whats actually in the tune file.
The cam in my sig is good til about 5600rpms it seems. A super ram or mini ram will swap directly into my build with nothing else, and produce a strong running top end car?
Old Nov 21, 2013 | 11:53 AM
cumbercr's Avatar
cumbercr
Either intake would make much better use of the cam's power range. Which one depends on what you intend to use the car for.
The Super Ram is a common choice for the street. It has good low end torque, significantly better flow over stock and the shortened runners raise the power band. I have recorded 6000 RPM with my 396 Super Ram. Super Rams are no longer manufactured, so it can difficult to find one.
The Mini Ram performs at a little higher power band than the Super Ram and will flow better. But the Mini Ram does give up some low end torque. A big advantage of the Mini Ram is the ease of installation.
Old Nov 21, 2013 | 11:59 AM
Its a daily driver that I like to have fun with, take to the 1/8 once in a while, I want to start auto-x and road racing, etc.
I wont need new fuel rails or anything else if I somehow find a cheap mini ram?
To SLP ported/siamesed runners?
Old Nov 21, 2013 | 12:06 PM
89L98TPI's Avatar
89L98TPI
If your interested in a Super Ram let me know.
Old Nov 21, 2013 | 12:21 PM
cumbercr's Avatar
cumbercr
If this is primarily a street car, I think you'd find the Super Ram to be a good choice. Even in the 1/8th it might be a better intake than the Mini. However the Mini would perform better in the second half of a 1/4 mile. That subject has been debated numerous times on this forum.
The mini ram does require their fuel rails. The Super Ram uses stock rails.
Old Nov 21, 2013 | 12:22 PM
^Thanks for the offer, '89.
I'm not trying to swap rails and all that right now. I guess I really just want to work out all the kinks and get this thing running properly first. Then body/interior. Then maybe i'll make rounds back to the motor
