Long start
Old Nov 25, 2013 | 05:25 PM
yvette94's Avatar
yvette94
Cruising
Default Long start
Hello,hope some one can help.
94 vette was getting a long start
replaced the fuel pump, i was getting no
pressure on the old one. new one in cranked
right up.Took it home sat for a few, went to
start same thing long start but it does start.I think i
replaced the fuel pump relay. At least it is where i
think it is located,under the dash on driver side.( it is
on a block of 4 other relays ?).
Thanks for any help.
Old Nov 27, 2013 | 02:29 PM
ejscarfo's Avatar
ejscarfo
Sounds like you're losing fuel pressure somewhere. Have you done a leak down test with a fuel pressure gauge? You might have leaking injectors.
Old Nov 29, 2013 | 08:14 AM
HlhnEast's Avatar
HlhnEast
How long does it have to sit before it has its long start? Does it crank right up when you are running around or does the long crank occur each time? If you turn the key on, wait 10 seconds, then crank does it fire right up? If you advance the throttle a bit does it crank right up?
Long cranks usually indicate leak down or low fuel pressure. The fuel pump is the main offender but since you replaced that you need to go on to other things like leaking injectors as indicated An indicator there would be a bit of dark smoke at crank up where the car is burning off excess fuel. Check all along your fuel lines for any cracks, loose fittings or anything that would allow air in. You should see dampness around these suspect points.
You should also check your TPS for correct voltage (0.54v), IAC for the right counts (20-30 I think). Cranking/running I think is also governed by adequate oil pressure. If the engine takes a while to build pressure or you have a bad sensor, that could play a role as well.
Good luck and keep us posted.
Old Nov 29, 2013 | 03:59 PM
yvette94's Avatar
yvette94
Cruising
Thanks for the feedback, okay this is where i am at,key on 20psi then drops (within 5 sec.)
to 0.Engine running 29psi stays there,take hose off fuel regulator does not idle up,still 29psi.
I applied 14 inches of pressure on fuel regulator as the shop manual says,no drop in fuel
pressure.If i push the accelerator id does drop.No dark smoke no fuel leaks or cracks that i can see.Thanks again.Bad regulator ?
Old Nov 29, 2013 | 04:05 PM
ejscarfo's Avatar
ejscarfo
Hmmm....could be. Was there any fuel in the vacuum line when you pulled it from the regulator?
Old Nov 29, 2013 | 07:15 PM
yvette94's Avatar
yvette94
Cruising
No fuel in vacuum line...
Old Nov 29, 2013 | 07:44 PM
pcolt94's Avatar
pcolt94
When you turn the key to ON, do you hear the pump run for 2 seconds. If it does not, then the engine has to build oil pressure to close the second switch for the pump. Then the fuel pump will start as so will the engine. Just another item to check
Old Dec 1, 2013 | 06:54 PM
yvette94's Avatar
yvette94
Cruising
Well i changed the fuel regulator and yes still the same problem and yes the pump does run for 2 seconds.
Old Dec 1, 2013 | 07:11 PM
Klyde's Avatar
Klyde
Every once in a while when someone installs a new fuel pump the new higher pressure of the pump pops the pulse dampener off between the pump and the exit tube. This sets or fastens directly to the top of the pump. Some times it rupture's it or an old hose. These are both inside the tank so you won't see or smell it. This can cause low fuel pressure and rapid pressure loss even though its a new pump because the pressure bleeds back into the tank. I have seen this on this forum multiple times and actually look for it when someone installs a new pump. The other thing that goes wrong with new installs is people get the sock on backwards and it gets pinched while putting it back together. I would pull the pump again and inspect it. It doesn't take long and may very well be the issue. The pinched sock just causes low pressure because the pump is starved. You should be getting high 30's to low 40's psi wise when turning the key on.
Old Dec 1, 2013 | 07:20 PM
JrRifleCoach's Avatar
JrRifleCoach
From: Freedom is never more than one generation away from extinction.
St. Jude '03 thru '24
I'm looking where the OP changed the fuel filter. . . .
Old Dec 1, 2013 | 07:52 PM
pcolt94's Avatar
pcolt94
100%
This is a good place to re-check and possibly find the solution. I think you will.
FPR has been eliminated and does not sound like it would be any kind of injector problem.
If fuel pressure is low, FPR will not operate properly and you will not see expected results.
Old Dec 2, 2013 | 07:02 AM
yvette94's Avatar
yvette94
Cruising
FYI the fuel filter was changed when i had a tune up done about a month ago.
To Long start
