traction control 85 vette ??
Old Nov 26, 2013 | 11:26 AM
dirtyd22's Avatar
dirtyd22
3rd Gear
Default traction control 85 vette ??
hey guys im new to the forum my problem is i recently traded for a 85 vette the car is in pretty good cond runs great, but when i get on it it starts to fishtail a little it cuts out til it stops spinning then kicks back in and goes ?? was under the impression that 85 models didnt have this feature .there are no buttons or switches for this that i can find . the only upgrades to the car are g-force chip , k&n , throttle spacer , any help or suggestions are greatly appreciated , thanks TONY .
Old Nov 26, 2013 | 11:47 AM
eatmydst1234's Avatar
eatmydst1234
'85 has no traction control, how much gas is in the tank?
Old Nov 26, 2013 | 03:17 PM
dirtyd22's Avatar
dirtyd22
3rd Gear
you know i wondered about that too > yes the tank was pretty low and i havent tried it since i filled up !! will try thankyou
Old Nov 26, 2013 | 04:09 PM
HlhnEast's Avatar
HlhnEast
If I get on my '85 when the tank is low it will try to shut down. There are mod fixes but just keep it above a 1/4 tank.
Old Nov 26, 2013 | 04:46 PM
cumbercr's Avatar
cumbercr
There's also no ABS. Just make sure you're pointing straight during hard acceleration.
Old Nov 28, 2013 | 02:05 AM
dirtyd22's Avatar
dirtyd22
3rd Gear
Default 85 vette
lol will keep that in mind !! thanks for the info guys
Old Nov 28, 2013 | 10:11 AM
Klyde's Avatar
Klyde
What! You bought a new car and the seller didn't even fill it up.
Old Nov 29, 2013 | 07:45 AM
HlhnEast's Avatar
HlhnEast
Funny! maybe in 1985 but in $3.50+/gallon times that would be more than the down payment!!
Old Nov 29, 2013 | 09:08 AM
hcbph's Avatar
hcbph
Default Gas
Could be worse. When I bought mine, without an owners manual I didn't find the gas gauge so I went for the first gas station I could find to fill it up. Took better than 18.5 gal to fill it. It's a wonder it even started but it did and went over 10 miles to the station.
It was via a car auction, but they could have at least left some gas in the tank.
Old Nov 29, 2013 | 01:21 PM
3D87C4's Avatar
3D87C4
How old are your tires? When I got my '87 the tires were about 14 years old & it didn't take much to break 'em loose.
Old Dec 6, 2013 | 03:52 PM
dt#2's Avatar
dt#2
Intl Council of Corvettes
You may want to try adding a set of these shim plates on the C Beam assy. These cars suffer from not be able to swat and go in a straight line sometimes. this is the url http://www.zfdoc.com/c4beamplate.htm they are inexpensive but maynot completely remove the fish tailing affect but it should be noticable.
I put a set on mine and that helped some but when you stomp on it froma stop it pulls slightly to the left until the tires grip.
To traction control 85 vette ??
