700r4 Help
Old Nov 27, 2013 | 01:55 AM
mauitom's Avatar
mauitom
Default 700r4 Help
Background, I have a level 2 700r4 Raptor trans. I've run it without issues for about three years. My car is a dedicated drag car, high 12's, low 13's, so not a beast by any means. I race about 15 times a year, 3.54:1 rear end gears. '84 car, the trans is from an '86.
I only manually shift the car. When I launched, after doing my burn out, the car did not move forward, well maybe a few feet. I was able to reverse out and limp back to the pits. When I went from 2nd to park there was a grinding noise. I again was able to limp home, 2nd and 3rd seemed fine, but I just baby'd it. Same noise getting it into park from third at home.
I am rebuilding it myself. I just now taking it apart, and just my luck, nothing seems to be broken so far. A tech guy at Monster transmission gave me a guess of forward sprag failed. Raptor won't respond to me. Fluid is clean and smells fine. There is, what I consider to be, a normal amount of black in the pan and valve body. Clutches I've removed all look fine.
So my first question, any guesses on what failed?
Mahalo,
Thomas C.
Old Nov 27, 2013 | 01:17 PM
Just BOB's Avatar
Just BOB
Originally Posted by mauitom
...just my luck, nothing seems to be broken so far. A tech guy at Monster transmission gave me a guess of forward sprag failed.
The sprag, or overrunning clutch is a good ffirst guess. If you are going to rebuild yourself, go ahead and order an ATSG rebuild manual (under $30 on line, eBay or Amazon). The manuals have more current info than an FSM and cover a range of years. The manual also has a chart the describes the torque path through the transmission for each gear selected. That chart, along with your synptoms will help focus your search for damage. You will need the info in the manual to properly reassemble the trans and set end clearances. The clearances can be off by quite a bit if you have to replace any hard parts.
Old Nov 27, 2013 | 02:58 PM
383vett's Avatar
383vett
I've lost a couple of sprags, plantetary gear and input shaft among other things. I would guess one of the first two is your problem.
Old Nov 27, 2013 | 04:35 PM
mauitom's Avatar
mauitom
Sorry, I should have mentioned I have rebuilt one before, so I have all the manuals, tools, etc.
In reviewing the chart on what is applied in each gear, it looks like the two areas that are used in low and not 2nd, the low roller clutch and low reverse clutch appear to be my best guess.
So far, I have the guts out and can't find anything broken. The breakdown was so sudden and clunky, I expected obvious broken parts in the case, which so far is not the case.
I'm reviewing how these two areas are applied in the valve body, perhaps I had a hydraulic failure in the valve body? That's my next area to examine.
Thank you for the replies, as always, I was hoping someone on the forum would say, hey! That happened to me! :-)
Old Dec 6, 2013 | 04:21 PM
dt#2's Avatar
dt#2
Intl Council of Corvettes
Don't know anything about Monster transmission but I would think Performance Torque Converters can help ya. They are pretty helpful people and they know the 700-R4s really good. I was just over there this mornning as I had them check my TC because we thouht is was leaking. Turns out it somehow developed a hair line crack of some sort in the pumphousing. My symtoms were not like yours it was just a constant drip when the engine got hot and was losing pressure.
Old Dec 6, 2013 | 04:25 PM
383vett's Avatar
383vett
The op is in Hawaii.
To 700r4 Help
