What would you do on a basic tune-up on a C4
Old Dec 15, 2013 | 09:32 PM
chstitans42's Avatar
chstitans42
TheCorvetteBen
Thanks for the step by step. No worries, the mother in law might be helping
Old Dec 15, 2013 | 10:00 PM
Silver96ce's Avatar
Silver96ce
Klyde has an LT1; your brother-in-law has an L98. The procedure is a little more involved for a 1991 L98. The intake manifold upper plenum and runners have to be removed to access the injectors on your 1991. If you go with FIC for the injectors get the manifold gasket kit and fuel rail kit. Plus if you do the injectors then also check the operation of the EGR along with removing it to check for carbon buildup. Also rebuild the fuel rail by replacing the o-rings (LT1 fuel rail doesn't need that) and replace or rebuild the fuel pressure regulator.
Old Dec 16, 2013 | 03:23 AM
Bluezman's Avatar
Bluezman
Hey, chstitans42...
I just wanted to mention that I don't have a brother-in-law. Would you consider taking me on as yours too?
Bluezman
Old Dec 16, 2013 | 07:46 AM
Just BOB's Avatar
Just BOB
Originally Posted by Klyde
... I then removed the wiring clips to each injector.
You don't remove the injector clips. You squeeze the clips inward against the connector housing.
Old Dec 16, 2013 | 05:06 PM
Klyde's Avatar
Klyde
Sorry. I meant the wiring connectors. Mines a totally different engine so it doesn't really matter at this point. My bad!!
