86 won't turn over
Old Dec 15, 2013 | 07:50 PM
Curt gentry's Avatar
Curt gentry
1st Gear
Default 86 won't turn over
Just got a 86 been sitting for 6 years cleaned the fuel tank and lines change all fluids put a new batt in it doesn't turn over with key can jump starter and it turns over fine when the key is in start position the seceruty lite flashes but no starter need help please.
Old Dec 15, 2013 | 09:52 PM
drjimmy's Avatar
drjimmy
Sounds like a vats problem. It can be bypassed with a resistor.
Old Dec 15, 2013 | 11:17 PM
don hall's Avatar
don hall
http://vats.likeabigdog.com/
Old Dec 16, 2013 | 03:32 AM
Cliff Harris's Avatar
Cliff Harris
It could be a VATS problem, but the SECURITY light has nothing to do with VATS in your car. That's a completely separate system.
VATS turns on the starter enable relay and also sends a 30 Hz square wave to the ECM. The ECM will not fire the injectors if it doesn't see that signal. You can tell if this is a problem by reading the error codes. VATS is code 46:
http://forums.corvetteforum.com/1574918379-post18.html
http://corvettephotographs.com/c4vettes/codes.htm
A list of error codes and what they mean is here:
http://forums.corvetteforum.com/1576116036-post35.html
This site has a good explanation of VATS and the various options for defeating or eliminating it:
http://www.joestradingpost.com/vats/
Old Dec 16, 2013 | 05:47 AM
Ray Quayle's Avatar
Ray Quayle
- 1986 Original Owner -
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In VII Veteran
Right on, Cliff. Great info, as usual. An important fact that Cliff implied, but some may not have understood him completely regarding code 46 on these early VATS cars is that the code is only set if the ECM does not see the square wave signal with the ignition switch in START or RUN. Of the two VATS module functions Cliff describes, only the lack of square wave signal will set the code. If only the enabling ground to the Start Enable Relay is absent, the ECM is not aware and doesn't set the code. Nor can code 46 be set by a failure of the Start Enable Relay or its associated wiring. Circuit 963 is the only connection between the VATS Module and the ECM, so the only criteria for a code 46 on these early VATS cars.
To 86 won't turn over
