TransGo boost valve
Old Jul 10, 2002 | 02:33 AM
merrick's Avatar
merrick
Default TransGo boost valve
This valve raises trans line pressure. I bought one for an 4L60E(truck). Anyone try this valve before? Should I add a trans cooler or cooler pan with it?
Old Jul 11, 2002 | 04:08 AM
merrick's Avatar
merrick
Default Re: TransGo boost valve (merrick)
Nobody? Alrighty then, I'll post my results.
Old Jul 11, 2002 | 09:40 AM
dgoodhue's Avatar
dgoodhue
A boost valve itself shouldn't necessitate a transmission cooler, but an additional tranny cooler is always a good idea. I have larger boost valves in both of my 700R4.
BTW what size boost valve is it?
Old Jul 12, 2002 | 04:04 AM
merrick's Avatar
merrick
Default Re: TransGo boost valve (dgoodhue)
Iam pretty sure it is .5" That's bigger than any factory one
Old Jul 12, 2002 | 04:27 AM
Half Fast's Avatar
Half Fast
On the 4l60E you can also raise line pressure by programming the PCM. Don't do both. :chevy
Old Jul 12, 2002 | 11:29 AM
dgoodhue's Avatar
dgoodhue
OK, I just want to make sure your not putting in a .471 which every vette should already have.
To TransGo boost valve
