stumble on acceleration
Old Jul 10, 2002 | 10:29 AM
konroh's Avatar
konroh
Default stumble on acceleration
Hi Guys,
I just noticed a problem with my car on the way in to work today...if I am at low rpm, and most noticably in 5th or 6th gear, and hit the throttle to half or more, I am getting what feels like a miss in the engine. It seems to go away by about 2k rpm. It did this once before a few weeks ago, and then seemed ok, and I couldn't re-create it, but now it is doing it all the time.
What do you think it could be? What should I look at first?
Thanks in advance!!
Old Jul 10, 2002 | 10:51 AM
konroh's Avatar
konroh
Default Re: stumble on acceleration (MarkU)
I have had that happen with low fuel, if I accelerate fast the engine cuts out for a second. Right now I have an almost full tank of gas, and the stumble is happening even at freeway speeds, trying to accelerate in 5th or 6th gear while under 2k rpms.
Old Jul 10, 2002 | 01:06 PM
92corvette's Avatar
92corvette
Default Re: stumble on acceleration (konroh)
I had these symptoms a few weeks ago. It would stumble bad under load at low RPM. I noticed it most If I shifted to second going real slow, it would stumble real bad. At that slow speed, sometimes the engine would even die. Trying to take off in second gear was impossible, would just die. Like yours, in 6th gear, if I pushed the gas down at less than about 1500 RPM, it stumbled bad. Once the RPM got up above 1500, ran like a bat outta hell.
In my case it was a weak opti-spark. probably the last thing you wanted to hear. I knew mine was weak because I had gotten it wet last fall.
I replaced the opti a few weeks ago and all is well. Good luck.
Old Jul 10, 2002 | 01:09 PM
konroh's Avatar
konroh
Default Re: stumble on acceleration (92corvette)
That is the last thing I wanted to hear, but it's what I was afraid of!! How do you test the opti? Where is the best place to pick up a new one? How much?
Old Jul 10, 2002 | 06:29 PM
konroh's Avatar
konroh
What else could be wrong besides the opti that would cause stumble on acceleration at low rpm's? I want to fix any cheap stuff before I spend the money on an opti. It seems like most people with a bad opti have problems at higher rpm? is that right or does it usually affect low rpm under load first? my car only has 41,000 miles on it, should the opti already be going bad? :confused:
Old Jul 10, 2002 | 08:15 PM
92corvette's Avatar
92corvette
WEll, you could try changing the fuel filter first.
I did, and it needed it too, just didn't fix the stumble problem.
Old Jul 10, 2002 | 08:18 PM
92corvette's Avatar
92corvette
Yea, I have read that other people opti symptoms happen at high RPM too. Maybe it's not your opti, I'm just saying that's the way MY opti acted when it was going out. Has yours ever gotten wet that you know of?
I hope it's something else easier for you.
Old Jul 10, 2002 | 08:22 PM
2UHONEY's Avatar
2UHONEY
It's probably the opticrap thing, mine went at only 10.000 miles.
$600.00 to replace because once you remove the water pump a new pump is a must.
Old Jul 10, 2002 | 08:26 PM
konroh's Avatar
konroh
well, I guess I can hope it's not the opti...but right now i am afraid it is, I am just trying to exhaust other possibilities before I change mine out. How long did you have the stumbling problem? Now that I think about it, this has been happeningfor a while, if I would make a turn in 3rd gear and then try to get on it right away, and once before on the freeway in 6th...
I have only been caught in the rain twice, although once was a big thunderstorm/downpour so i hope that didn't do anything. I don't know what the previous owners did, but I think it wasn't in the rain much based on how clean everything was when I got it...
oh well, I guess this is one of the joys of owning a vette ;)
Thanks for the help guys...
To stumble on acceleration
