I have a set of vortec heads on my engine(1970 ) in the garage. I had to buy a special manifold for a carb and about to but one for the TPI on my 86.This is a decent read about vortec heads , http://www.chevyhiperformance.com/howto/97458/
be aware that 87 and later engines used a roller cam but real vortec headfs diddent appear until 96. Many confuse centerbolt heads with vortecs. Apples and oranges. Scroggins/Dickey , down texas way have a lot of hotrod stuff for the vortecs as well as other chevy engines. They claim there vortec manifold for the TPI adds 50 hp just by itself.
more concerned about wiring and getting fuel injection to work with a vortec engine than anything else
I put the vortec engine in my 98 chevy p.u. together from spare parts, still runs great for 8 years now. I always wondered what it would be like to have it in my 84 vette. As long as you can get all the wiring and related along with the engine, the biggest part will be the wiring and making sure the induction clears the hood.
If I were you, and you want to go to a vortec engine, I would get an ecu and the wiring harness for that engine. Don't bother with trying to re-use the 84 ecu and wiring. The connection between the harness and ecu on the 84 is unique, my toaster has more brain power than the 84 ecu, and the insulation on the wires are probably like the toast crumbs on the bottom of my toaster, by now. The only thing you will lose with a different ecu is the current/average mpg display. The speedometer would not be affected at all. The Tach probably not. The thing to make sure of, is all the wiring connections. This is where it gets tricky. You need to make sure all the connections are correct for it to work correctly. On the 84, the speed input into the ecu come from the dash, not the transmission vss. With the "new" ecu, what kind of signal is it looking for (rhetorical question)? Is it the same as the 84 (rhetorical question)?
what would be needed to make the speedo work, if it helps its a Z51 car with the 3.07 rear
wasnt actually aware there were auto Z51s until i saw it
Are you asking how to make it work with a different ecm? If so, at worst you would have to get a signal converter to put the right signal to whatever ecm you use. Right now the vss signal runs to the speedo first, at 4000 pulses per mile, then gets sent to your ecm by the cluster at 2000 pulses per mile. I think (not sure) that the vortec ecm will be looking for a 4000 pulse per mile signal. If that is the case, just tie into the vss wires going to the cluster to run the signal to the vortec ecm instead of using the signal from the cluster. After that you may need to get the ecm reprogrammed with your final drive gear ratio. The vortec ecm normally controls a 4L60E transmission (if automatic), but yours is a 700R4 (similar without the electric shift solenoids) Maybe that can be programmed as well.
yes, i would like the make the speedo and tach work with a different ecm
onto another issue, it idles correctly now and seems to burn less oil
but the brake pedal is hard and has very little travel and the brakes dont stop very well
i dont see any vacuum leaks and while the brake fluid is a little dirty, it isnt low and i will change it later, but i dont think that would cause this
what might be the problem?
also the transmission makes a loud metallic clunking when shifting into gear
i think it could be u-joints but not sure
also i think the problem with the brakes is the booster
Do you have a vacuum gauge to see how much vacuum the engine is making? also check the vacuum check valve on the booster. Does the pedal feel any different with the engine running, and engine off? If the check valve and booster are ok, you should be able to let the car run to build up vacuum, then shut it off and wait a few minutes, and you should get at least one push on the pedal that feels about the same as when the car is running. The transmission clunking could also be that the c-beam bolts have loosened up, mine were like that. Check them at the front on the transmission tailhousing and at the rear on the differential housing while you are checking the u-joints for play.
no vacuum gauge but what makes me think the brake booster is dead is the fact that it hisses, and i cannot press the brake pedal to the floor
going to just replace it, seems to be a 10" unit, but i am wondering if only other 10" units will fit or if a 9" or 11" booster would work as well
