Need a more street-friendly combo
" I've done several mods to it including 226/230/595/595/111lsa Bullet cam, AFR 195 Street Eliminator heads, Edelbrock intake, Installed a Dana 44 3:45 rear end, MSD opti,LS7 lifters, hardened push rods. 1.7 roller rockers, TPIS 1-3/4" long tube headers. 2800 stall converter (Pete's) Lots of bolt ons also. Mileage is 101K..."
"A few more mods are: high volume fuel pump, adjustable fpr, MSD plug wires, Meziere electric water pump, new radiator and hoses, C- beam plates, double roller timing chain, TPIS long tube headers,58 mm Performance Products throttle body, Bosch III injectors (36's I think), DMH electric cutouts, X pipe, high flow cats..."
I'm thinking a more conservative cam and a set of 1.6 RRs along with a dyno tune by our local speed shop (Virginia Speed) would do the trick. What are y'all's thoughts? LT4 hot cam, maybe? What are your thoughts about reusing the opti and water pump since they are both working good?
What is the length of stock pushrods so I can order an adjustable pushrods tool to make sure I am measuring in the right range?
Any insight y'all can give is appreciated.
Chris
I'd certainly believe this would be where I'd start. You mention 101K but you don't mention the miles on the on the engine mods. It might be foolish to go after the engine mods if there's a lot of miles on the build already. Have the package "as it sits" evaluated by Virginia Speed.
Your intended changes would be completed by who? Yourself or a shop?
Do a search on him and you will see he has many satisified customers on here.
Ed is class act.
I'd take the reference by "93 ragtop" as a "first class" referral and I believe a comment "Ed is class act" as a second might be great but I don't know that I would be so critical of a possible choice by the OP.
"crap half-assed" is maybe an assessment that is "personal"!
*** Looks like the OP is maybe wisely "shopping".
That cam is perfect if you use it with the right rocker. Change these out, and retune it and you should be good.
Maybe some "cruise/part throttle" time on the tuning end could cure your ills.
Try it as much as 8-degrees advanced.
Chris
If the cam is really .595 with 1.5's, 1.7 RR is a ton of lift -- meaning you're well into the 600's for lift. That would be a very aggressive cam. It SEEMS more likely that you're hitting .595 with the 1.7's. If so, you're probably not going to gain much drive-ability (by lowering them). There are varied opinions on the degree of lift vs longevity. I had decided mid .500's was about the limit w/o swapping springs every couple of years. Engines with .600 lift are generally fairly aggressive and often require more periodic maintenance. Matching lift to the AFR195's is typically the goal for builders though...and having .600 lift -- with those heads -- is prime time. So, it can be a question of longevity versus performance.
The functional difference between 1.5 and 1.7 rockers is about 4 degrees of valve duration IIRC. It's doubtful that make/break the difference in performance. If the cam is retarded, advancing it would make more difference.
If the tune isn't right, that will make the most difference.
Chris
Gregg' this sounds like "WeavsVets" car, and if I remember correctly the 595 lift was with 1.7 rockers.
V/r,
Chris
If the geometry is very good, you're fine. And, that's really the kind of lift you want to get the most out of the AFRs.
As mentioned in prior posts, check your springs every couple of years. Maybe more often if you put lots of miles on it.
So did you buy "WeavsVets" Corvette?
