sys flashing??
Old Dec 30, 2013 | 04:54 PM
Dano86's Avatar
Dano86
Default sys flashing??
I have a 1992 lt1 that I had to jump start this morning. It don't get driven to much in the winter here.
As I was driving I noticed an "SYS" blinking in the gauges that give a digital read of oil temperature coolant temperature voltage fuel info ECT. It blinks three or so times then gives me my reading and flops back and forth.
What could this mean??
Thank you
Dano
Old Dec 30, 2013 | 06:24 PM
MTVette's Avatar
MTVette
You'll get a blinking 'SYS' whenever the battery has been discharged or needs replacement. Try to pull out the computer's fuse for a moment to reset the error code. If it returns, you probably need a new battery.
Old Dec 30, 2013 | 06:38 PM
DUB's Avatar
DUB
Thank you
Dano
The "SYS" flashing:
This is telling you that you have a trouble code in the Central Control Module (CCM)...which some call the Body Control Module (BCM) This is NOT a code in the ECM or PCM. This/these code(s) can me manually accessed and read so you can find where the problem is located in the CCM...and it will give you a code ..and thus it can be diagnosed and repaired.
From personal/professional experience...jump starting battery does not cause this "SYS to flash ( unless you used a jump box, battery charger with really serious amps..much higher than what the alternator produces and tried to start it with a really high amp charge). I am NOT stating that jumping it can not cause it...I have never had it cause it...it was always something else that causes the SYS to flash.
DUB
Old Dec 30, 2013 | 06:47 PM
vetteoz's Avatar
vetteoz
Originally Posted by DUB
The "SYS" flashing:
Pull the codes
http://www.corvette-guru.com/uploads...CMCodePull.pdf
Pay special attention to which module you are in when reading a code
Old Dec 30, 2013 | 09:40 PM
RollaMo-LT4's Avatar
RollaMo-LT4
St. Jude 15 Year Donor
2021 C4 of the Year - Unmodified Finalist
St. Jude Donor '10 thru '25
Thank you
Dano
Time for a new battery
The SYS flashing every few minutes indicates an electrical system fault.
Number one cause is a discharged/bad battery
Old Dec 31, 2013 | 07:22 AM
AirForceOne!'s Avatar
AirForceOne!
Get a battery tender and you won't have that problem in the winter!
I got this one at Auto Zone for $39. It works great!
http://batterytender.com/products/au...-at-0-75a.html
Old Dec 31, 2013 | 03:24 PM
Dano86's Avatar
Dano86
Well that is good news hopefully. I will change it when I get back into town next week.
Thanks y'all!!
Old Dec 31, 2013 | 06:35 PM
DUB's Avatar
DUB
If the alternator is charging (13.6 to 14.4 volts approx) and shows on your display when the engine is running. If it is below the above mentioned voltage values...lets say charging at or below 12.0 volts. Then you have an alternator issue. I really do not think that it is a voltage issue due to the alternator is working if it is in the 13.6-14.4 voltage values. Replacing the battery may correct a weak or low battery...but without you pulling the CCM trouble code(s)...it is hard to say what the problem is. I would do this before I installed a new battery.
Please inform us on the progress when and if you change the battery and the SYS light still flashing. If it goes out...it would be the first one I have encountered due to this issue. Would not be the first time.
DUB
Old Dec 31, 2013 | 08:32 PM
SoAlVette's Avatar
SoAlVette
Mine flashes because I installed an aftermarket stereo that does not work the auto dimmer.
Old Dec 31, 2013 | 08:41 PM
RollaMo-LT4
DUB
It is very common to have a low battery cause the flashing SYS.
It is not a constant flashing, but just a flash every few minutes.
I have experienced it with my '96, and it has been reported here many times.
The fact that he had to "jump" the car to get it started leads one to question the quality of the current battery.
He may not have a "bad" battery, just one that isn't fully charged.
It might also be toward the end of its useful life. A battery that has been discharged enough to require a jump usually will not ever come back to a full "like new" charge.
Old Jan 8, 2014 | 02:58 AM
Dano86's Avatar
Dano86
Well after the car sat for 7 days it fired right up with the old battery (little slow on the crank but still fired right away). Pulled the codes they are 1.1 H23, H71, H72, and H73. I will look them up tomorrow and see then.
Old Jan 8, 2014 | 05:16 AM
desertmike1's Avatar
desertmike1
I personally don't like "jumping" it can cause a power surge in the electrical circuits.. and we all know computers don't like power surge's! If your stuck on the road, well that's one thing.. in your driveway it can be avoided.
Here is another good site for code descriptions, and retrieval.
http://tech.corvettecentral.com/2011...trouble-codes/
Old Jan 8, 2014 | 02:32 PM
GKK's Avatar
GKK
The "H" represents a History code that was for a previous fault that was most likely repaired and never cleared.
A "C" displayed, would indicate a Current code.
Old Jan 8, 2014 | 02:52 PM
Dano86's Avatar
Dano86
thank you for this link. another very helpful one! they where all history codes so I cleared them yesterday when I was messing with it!
Thanks again
Old Aug 6, 2014 | 11:25 AM
scotth48's Avatar
scotth48
That sight was very good on how to access ccm codes and to give the condition for each code. It was a better explanation than the fsm had and the pictures too. I saved info to a word file for future use, I'm sure it will be needed again some point in time!
Now I can see what my problem may be as I was requesting help for asr service message on the dash on the forum.
Thanks.
To sys flashing??
