Where is sensor for analog temp gauge on 95
Old Jan 18, 2014 | 05:03 PM
corvette95's Avatar
corvette95
Default Where is sensor for analog temp gauge on 95
My 95 needle gauge is stuck all the way past full hot. The digital readout is fine and I am not overheating. It wont move with engine on or off, hot or cold, just stuck full hot. Does this sound like bad gauge or bad sensor? 95 LT1.
Old Jan 18, 2014 | 07:04 PM
aboatguy's Avatar
aboatguy
Its on the side of your head.
I broke one back in 2005 installing headers
As for gauge or sensor.... you'll have to troubleshoot since it could be a bad connection too.
Old Jan 18, 2014 | 08:04 PM
FASTAZU's Avatar
FASTAZU
2018 C4 of Year Finalist
2015 C4 of the Year Finalist
St. Jude Donor '16
You also have a coolant temp sensor on the front by the water pump.
Old Jan 19, 2014 | 08:05 AM
C409's Avatar
C409
..... The gauge sender is usually found on the pass cylinder head between #6 and #8 ... the sender in the LT water pump is for the ECM ...........
Old Jan 26, 2014 | 02:07 PM
corvette95's Avatar
corvette95
Can anyone post a trouble shooting tree from the service manual for the analog gauge? Mine is stuck full hot, digital reads 193. I have ruled out cluster. I found my sensor, it was hooked up with one green wire, though if I grounded it unplugged it would show full cold but no change.
Old Jan 26, 2014 | 03:51 PM
67Olds442x2's Avatar
67Olds442x2
Looks like a short to ground somewhere.
Old Jan 26, 2014 | 06:31 PM
corvette95's Avatar
corvette95
Thanks for your help, I found a shorted wire right where I cant reach on top of manual transmission bellhousing, I need some high temperature loom or something.....any recommendations? ...other wires are getting melted as well.
Old Jan 26, 2014 | 09:30 PM
67Olds442x2
I'm using Painless Performance's wire wrap to do my whole engine harness.
http://www.summitracing.com/search/b...rder=Ascending
There is probably other stuff similar to the factory wrap, I just find that stuff hard to work with.
Old Jan 29, 2014 | 07:54 AM
corvette95's Avatar
corvette95
Thanks! I will buy that!
Old Jan 29, 2014 | 08:22 AM
WVZR-1's Avatar
WVZR-1
You shouldn't need to order that product. Any larger electrical supply house, some auto parts stores or even a good local hardware store should have it.
Buy "local" - no shipping and it might be a friend or neighbor that could use the sale!
To Where is sensor for analog temp gauge on 95
