remote mount turbo setups
Old Feb 21, 2014 | 01:49 PM
  #41
Impala Balko's Avatar
Impala Balko
What is the best type of T4 gasket to use stainless, copper, or other
Old Jun 6, 2014 | 11:14 PM
  #42
Impala Balko
So i should be getting my car back Monday evening from the exhaust shop. I had them run the hot side and fabricate the mounting bracket for the turbo. After this I can run my oil lines and fabricate the cold side.
Now my question is what gap spark plugs should I get... I have heard about using colder plugs for boosted motors but I don't quite understand what that means exactly
Old Jun 10, 2014 | 07:33 PM
  #43
Impala Balko
Update. ... car is at the exhaust shop getting the hot side worked on
Old Jun 11, 2014 | 12:33 AM
  #44
ANTI VENOM's Avatar
ANTI VENOM
Spark gap: Depends on boost and your ignition. I would think .030-.035 would be a good place to start. MOST theories say the wider the better as long as it will jump the gap and not blow out.
You may want a colder plug, again, depending on boost. Basically a "colder" spark plug has a shorter insulator to firing tip length allowing it to cool quicker then the longer insulator "hot" one. Boost will make the combustion temperatures rise. If the spark plug gets hot enough, it can start to ignite the mix before it sparks. (detonation) If you use too cold of a plug, you can foul the plug with rich mixtures or oil. I wouldn't recommend any of the "fancy" plugs either.
Old Jun 11, 2014 | 06:50 AM
  #45
BrianCunningham's Avatar
BrianCunningham
From: Boston, Dallas, Detroit, SoCal, back to Boston MA
Looking good
Glad you found a shop
Old Jun 15, 2014 | 06:38 AM
  #46
Impala Balko
Well I have the tail pipe assembly, wastegate, oil feed line run (just need to tap the block), and the scavenge pump is mounted but I just need to build a more secure mount.
Old Jul 3, 2014 | 12:15 PM
  #47
mn_vette's Avatar
mn_vette
What are you using for a scavaging pump? From the pics it looks like a basic diaphragm pump for a differential cooler or similar. You need to determine what the flow rate of that pump is.
I have tried something similar on my car before I went with a more traditional system and I had to limit the oil flow to the turbo to let the pump keep up and it killed the turbo after a short period of time. If I didn't limit the flow it over ran the pump and started coming past the turbo seals.
And as the oil temperature changes the oil flow into the turbo will also change. Oil will flow much more when it is warmed up. If you look at the STS oil pump it is a pretty heavy duty pump. I believe it is not a diaphragm pump and flows a good deal.
As an experiment you may want to disconnect the turbo drain line and put a bucket under it and then put the pump hose in the bucket and just see if the pump will keep up with the oil draining into the bucket. Make the bucket is spotless before you start of course.
Old Jul 4, 2014 | 09:52 PM
  #48
Impala Balko
The scavenge pump is a Turbowerx scavenge pump (base model pump) which from what I've read is supposed to be one of the best pumps to use.
Old Jul 6, 2014 | 11:54 AM
  #49
Impala Balko
Quick Boost/Vacuum Reference question.... Can I just get my boost/vacuum reference for my Blow Off Valve/boost gauge off of any manifold vacuum source or do I have to use a specific one. The write up that I have been following states to use the brake booster hose but I figured it would be way easier to just use one directly off the intake manifold like the one the cruise control module gets its vacuum source off of.... Is this correct?
Old Jul 7, 2014 | 09:20 AM
  #50
mn_vette's Avatar
mn_vette
That pump definitely looks like it will do the job.
I would pull the BOV vacuum line off of the intake manifold directly. When you close your throttle and you get good vacuum in the intake it will help pop the BOV open. I wouldn't try to add it to another function, just make a new tap on the intake(remove one of the plugged ports)
The brake booster may be suggested since it is a larger tube from the manifold and it is always going to be there on any application.
Old Jul 22, 2014 | 08:42 PM
  #51
Impala Balko
What size fuse should I use with the Turbowerx "Spartan" base model scavenge pump
Old Jul 23, 2014 | 01:44 PM
  #52
mn_vette's Avatar
mn_vette
Here's a link to the manual for the pump. It says to use a 10A fuse.
http://turbowerx.com/Scavenge_Pumps/...mp_Manual.html
Old Jul 23, 2014 | 09:42 PM
  #53
Impala Balko
I had a 10amp and it keeps blowing it
Old Jul 24, 2014 | 09:53 AM
  #54
mn_vette's Avatar
mn_vette
How do you have it wired up? Are you using a relay, switch, or what?
As a sanity check you may want to take a 12V battery and wire it directly to the motor with a 10A fuse. This will let you know if the wiring is a problem or the motor has a problem. If the wiring is ok then you'll need to give turbowerx a call.
If this blows the fuse then you've got motor problems.
Batt+--------10AFuse--------Motor+==Motor- ----Batt-
Old Jul 25, 2014 | 06:13 AM
  #55
Impala Balko
I wired it directly to the fuse block with a 10amp mini fuse
Old Nov 27, 2014 | 02:10 AM
  #56
DR76's Avatar
DR76
Default Redirecting...???
Originally Posted by hitmanpty
here very good side. about turbo charger . is all you need to know about turbo. you can download step by step instructions. and is free
http://www.junkyardturbos.com/index.php
Is this site still online? I get redirected to "zapcamz . com" and Google searching for "junkyardturbos" isn't getting me there...??? Ugh!
Old Nov 27, 2014 | 10:13 PM
  #57
aDigitalPhantom's Avatar
aDigitalPhantom
For now you can find the information here http://web.archive.org/web/201310050....com/index.php but there was no free download you had to buy it.
To remote mount turbo setups
Old Nov 28, 2014 | 07:57 PM
  #58
DR76's Avatar
DR76
Thanks ChevyOwner! I have a '76 and installed a '95 LT1/4L60e, which gave it a good spankin', but a turbo would just Kick It's ***! Probably will get the "General Turbo" and "F-body Rear Mount" books/downloads. Hopefully, I'll make this a project someday, but will be some good reading, none-the-less!
Old Nov 28, 2014 | 10:07 PM
  #59
aDigitalPhantom
That link is just to a web archive. I doubt you will get anything if you use the paypal links.
Old Nov 29, 2014 | 08:29 PM
  #60
DR76's Avatar
DR76
RATS... you are correct! I'll start a new thread and maybe someone who has downloaded any of these eBooks/PDF's will be willing to share...???
