Hi all
I replaced the original 16" wheels and tires on my 85 with 315/35/17s now I think there's a gap that's to big between the fender and the tire. I bought the rear lowering bolt and bushing kit from corvette mods my question is if I lower the rear 1"1/2 or 2" will that affect the alignment?
Hi all
If what you bought were bolts maybe 10 - 11 long and the cushions at the spring mount only there will be no changes to the alignment when installed. If you change anything else while you're there it's a "game-changer" You likely received 4 - cushions, 2 bolts/nuts and maybe washers. A preferred cushion would have been a "rubber/steel" bonded affair - I've no idea what they might supply.
