Torque arm
Old Jan 28, 2014 | 12:28 AM
BV85's Avatar
BV85
Default Torque arm
Where would this torque arm be mounted. What is it's purpose. Any help with this will be appreciated. TIA:
Old Jan 28, 2014 | 12:31 AM
DanielRicany's Avatar
DanielRicany
It goes along the drive shaft and mounts to the transmission tail shaft housing and differential.
Old Jan 28, 2014 | 12:52 AM
BV85's Avatar
BV85
Default Torque arm
Are you talking about the c brace. I just saw this part and looks nothing like c brace. In HUSS NEWMAN website. TIA:
Old Jan 28, 2014 | 12:55 AM
DanielRicany
Do you have a link to it?
Old Jan 28, 2014 | 01:02 AM
BV85's Avatar
BV85
YES it's NEWMAN CARS CREATION. My spelling isn't very good.
Old Jan 28, 2014 | 01:11 AM
vetteoz's Avatar
vetteoz
So got a link to what you are talking about?
Is it for a C4
or for a C4 suspension when fitted into one of Newmans many different chassis that require something to mount the front of the diff to?
Old Jan 28, 2014 | 01:16 AM
BV85's Avatar
BV85
vetteoz I know about the c brace. What I was looking at is very different.
Old Jan 28, 2014 | 01:23 AM
BV85's Avatar
BV85
vetteoz I really don't know. Doesn't give much info on it.
Old Jan 28, 2014 | 01:24 AM
vetteoz's Avatar
vetteoz
Hence the need for a link to what you are referring to,
given there is no torque arm on a C4
Old Jan 28, 2014 | 09:37 AM
BV85's Avatar
BV85
vetteoz This is www.newmancarcreation.com/products/ all I could find. Hope this helps you help me. TIA
Old Jan 28, 2014 | 10:33 AM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
OP...help us, help YOU.
Vettoz, he may be talking about this:
OP: this would be mounted on the rear diff, and then attached to the floor pan somewhere forward near the rear of the trans (depending on the vehicle). It is to be used in a car other than a C4 Corvette, that is using C4 Corvette rear suspension/diff.
Old Jan 28, 2014 | 12:07 PM
383vett's Avatar
383vett
This thing looks like an Fbody torque arm.
Old Jan 28, 2014 | 12:31 PM
rklessdriver's Avatar
rklessdriver
Tom is correct.
Thats an aftermarket part used to swap a C4 Corvette Independant Rear Suspension into other cars.
Since most other cars have a tranny crossmember and a very small trans tunnel there is no need or room or the factory C-Beam.... but since they still need a way to secure the pinion of the new IRS they mfgr'd this TQ Arm.
Will
Old Jan 28, 2014 | 12:47 PM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
Wrong side of the Diff.
That and it looks way prettier than that F-body slab of stamped steel..
Old Jan 28, 2014 | 03:01 PM
BV85's Avatar
BV85
Tom400CFI you are right. It's also used for the C-1 C-2 Thanks everybody. Just got off the phone with PAUL at newman car creation. So you were right. TIA
To Torque arm
