pinging
Old Jul 12, 2002 | 10:32 PM
antroc's Avatar
antroc
Cruising
Default pinging
hi my name is antoine and i have a 1988 camaro .30 over trickflow heads hooker headers 24pound injectors comp cam 220/230dur 510/510 lift 114lop installed walbro 340m with hotwire kit and holley regulator and paxton superchager hi output 10psi 3200 b&m stall problem is pinging alot when warm when on freeway will ping at around 3,000rpm or up not even full throttle and also with pressure should i set it at with vac off regulator or do i need race gas only can have fun when cold :mad
Old Jul 15, 2002 | 04:57 AM
Mo_Bandy's Avatar
Mo_Bandy
Default Re: pinging (antroc)
antroc,
Running 10 pounds of boost I hope you have an intercooler... In hot weather you will need to back off on your timing.. do you have like a MSD BTM ? If not I'd suggest some equivelant to that... 2300 to 3000 is where the s/c starts to buld boost... so that makes sense of not even at WOT... your ignitionis probably advancing too far... you need to look into that..
pinging or detonation is VERY bad on your engine.. you'll be picking up pieces of pistions out of the oil pan if you don't resolve it...
You can drop your plugs perhaps one step colder in heat range .. that may help some.. if you don't have an intercooler (one would dramatically help)... you should drop you boost to some where between 6-8 pounds...
You fule regulator should be set with the vacuum disconnected then put the vacuum line back on... if you don't have a fuel pressure guage.. or a boost guge you should have them installed... which 24 pound injectors yoshould be pushing about 80-85 pounds... see the other thread i responded to you on...
Best regards,
mo
