Maximum overbore on LT1
Old Jul 13, 2002 | 06:34 PM
kawboy5792's Avatar
kawboy5792
Default Maximum overbore on LT1
how much can you overbore the LT1 block safely? i wanna do a stroker, and the bigger the better! thank you all! :cool:
Old Jul 14, 2002 | 01:21 PM
95wht6spd's Avatar
95wht6spd
Default Re: Maximum overbore on LT1 (kawboy5792)
I know I have seen 429 and I think there are some 43x motors out there. I think I read somewhere on here recently that someone was going to do a 454?( I don't see how) I would just do a 396 or a 409. I think above this you are getting on the edge and longevity will be an issue. Probably better to start with a 400 block and go from there.
Old Jul 14, 2002 | 01:44 PM
GlockLT4's Avatar
GlockLT4
Default Re: Maximum overbore on LT1 (95wht6spd)
I'd say if you're going anything more than .060" over .. either get sleaves put in there, or just get a bigger block. The highest I've ever seen is a 429 as well. Highest in person is a 402.
Old Jul 14, 2002 | 10:57 PM
Chris@SD's Avatar
Chris@SD
These are made from bowtie or rocket blocks, not production blocks. Especially not LTx blocks. Even at .060" over bore, you have to be careful. Not all blocks will go that big.
To Maximum overbore on LT1
