1994 coupe map sensor
Old Feb 9, 2014 | 05:44 PM
Erniep's Avatar
Erniep
Default 1994 coupe map sensor
I want to replace my map sensor and I came across 2 different part numbers. a/c delco 213-3205 and 213-1545. Does anybody know the difference of the two ? And which one should I use ?
Old Feb 9, 2014 | 06:36 PM
DUB's Avatar
DUB
I would call GM and ask them. You did not specify what engine you have in the car because there were two engines offered for that year.
Can't help if you do not give all important information.
DUB
Old Feb 9, 2014 | 06:59 PM
Erniep's Avatar
Erniep
I have the base model. 5.7 ohv. I believe the zr1 had the other engine 5.7 dohc
Old Feb 10, 2014 | 01:50 PM
Erniep's Avatar
Erniep
Any replies ?
Old Feb 10, 2014 | 06:25 PM
DUB's Avatar
DUB
I took the time to look it up but confirm it with a GM dealer...but it should be the 1545.
DUB
Old Feb 10, 2014 | 08:26 PM
Erniep's Avatar
Erniep
DUB
thank you. I appreciate your time.
To 1994 coupe map sensor
