Fuel pressure regulator
Old Feb 10, 2014 | 12:28 PM
Charles.rogers1's Avatar
Charles.rogers1
Default Fuel pressure regulator
My 96 has an aftermarket fuel regulator (not sure of the brand or any details) but it gets in the way of me putting my fuel rail covers on.. Is there any way I can move it or kind of push it off the to the side so it will go on?? any tips on what other people have done would be awesome!!
Old Feb 10, 2014 | 02:31 PM
Joe C's Avatar
Joe C
pics would help...
Old Feb 10, 2014 | 05:42 PM
Charles.rogers1
Yeah I will post some when I get home from work!
Old Feb 10, 2014 | 06:27 PM
dogfish246's Avatar
dogfish246
If you look at 4:15
you can see how the stock one is set up. I dont know if you can really move it backwards because the fuel lines are solid near the regulator. Maybe someone has a good idea on how to move the fpr away from the fuel rail.
Old Feb 10, 2014 | 06:33 PM
Klyde's Avatar
Klyde
Since the fuel pressure regulator is inserted into the fuel rail I don't think you could move it elsewhere. Can you not just cut the plastic cover to allow it to fit better?
Old Feb 10, 2014 | 06:35 PM
383vett's Avatar
383vett
Dremel the cover.
Old Feb 10, 2014 | 10:34 PM
Charles.rogers1
that is what I was thinking I will have to do, here are some pictures anyways, maybe I just fail and cant get it to fit??
Old Feb 10, 2014 | 10:50 PM
corvetteronw's Avatar
corvetteronw
Cruise-In VII Veteran
Cruise-In VIII
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16
Pics from my previously-owned 96. Hope they help:
Old Feb 10, 2014 | 11:02 PM
JoeUser's Avatar
JoeUser
If it's that much of an issue, why not just order a
replacement replacement
one for $38?
Or, just do as others suggest: Break out the dremel.
Old Feb 11, 2014 | 05:22 PM
Charles.rogers1
I dremeled it out a bit and I think it is sitting all right for now, Can anyone post me a couple pictures of all the wiring on the passenger side? the shop did a pretty ****** job at wire routing and it will not clear the wiring.
Old Feb 12, 2014 | 01:05 PM
corvetteronw
Cruise-In VIII
Here's pics of and LT4 from the NCM:
Driver's side in case someone wants to see it:
To Fuel pressure regulator
