heated 02 sensors?
(2) Denso 234-3094 3 wire heated O2 sensors.
(2) EFI Connection 3 wire heated O2 sensor harness pig tails.
http://www.eficonnection.com/eficonn...spx?ItemId=555
It's up to you to wire in the heater and ground wires.... most folks use a 40A relay wired off the ignition (switch on) power to supply 12V+DC to the heater wires.
Will
Denso 234-3094 Oxygen Sensor : Amazon.com : Automotive
Amazon.com: Car Auto Truck Relay & Socket SPDT 12V 12 Volt DC 40A AMP 5Pin: Automotive
Will
Thanks Again Will, You are one of the most knowledgeable guys I have come across when it comes to C4 corvettes and modifications!
