A/c programmer
Old Feb 23, 2014 | 02:16 PM
Roncap's Avatar
Roncap
Default A/c programmer
Any one tell me how to remove the a/c programer? I'm going through the service manual step by step and it tells me to disconnect the heater and a/c programmer connector. Any one know how to remove the connector from programmer
Old Feb 23, 2014 | 05:42 PM
pcolt94's Avatar
pcolt94
You have to first remove the knee pad from the driver's side for visibility. Screws on bottom and the side.
One screw holds in the programmer.
The programmer won't drop down till you remove the connector.
Get a flashlight with lots of light. This is the hardest part. There is blue tab you push down and the connector will release, not easy to do.
Once that is done, the box will drop down where you can get to it.
The cardboard backing is held on with tape so just open it up so you can see the boards.
Remove the small one and let it hang. 2 screws.
Remove the big board and take it out. one connector, 2 screws.
Did you see my PM to you and the end of your original thread with the actual repair instructions and link?
Old Feb 24, 2014 | 03:49 AM
Cliff Harris's Avatar
Cliff Harris
pcolt94's description is for the later unit. If your car is older than 1990 then it's completely different.
The programmer is held by one 7mm screw. The hardest part is getting the clip off the silicone block that has all the vacuum lines coming out of it. That clip is buried in the middle of the vacuum lines and may be hard to find.
Old Feb 24, 2014 | 11:04 AM
pcolt94's Avatar
pcolt94
Its a 1992 car so I think my information is valid.
The clip and vacuum hoses are a pain since the clip usually has to be broken which adds just another thing to repair. But the whole box does not have to come out to service the circuit board. That's why I leave the lines connected. The board with the vacuum relays are probably just fine, the main control board comes out easy.
Old Feb 24, 2014 | 12:47 PM
leesvet's Avatar
leesvet
Make friends with the midget down the street.........
Old Mar 2, 2014 | 07:22 AM
Roncap's Avatar
Roncap
Programmer needed to be replaced. Got it out and found the no 4 pin broken orange wire that's what sends power to the programmer.now it all works. Now for the last problem the instrument that shows mph and fuel levels go on and off? When it goes off I can hit the top of dash comes back on sometimes any hints? Thanks for everyone's help
Old Mar 2, 2014 | 11:39 AM
pcolt94's Avatar
pcolt94
That's a good find. Sounds like it was a man made problem.
Your moving forward.
To A/c programmer
