Odd electrical problem ?
Old Feb 26, 2014 | 06:57 AM
C4in mesa's Avatar
C4in mesa
Default Odd electrical problem ?
Last night I was at the gym and when I got in my 1988 to go home I got in and turned the key. The car started up right away and ran just fine. I pulled the light **** and nothing happened. The radio would not respond either. The interior lights would not come on. The gear indicator light would not come on. The panel where the door open and SES light was off. I turned the car off 2 or 3 times and the problem would not go away. I disconnected the battery and that did not work either. I did that twice. The lights under the hood were not working. I went around and checked the fuses and they all showed no indication a fuse had burned out. Since I was in the city and the street lights keep the streets light well enough I decided to go home anyway. The flashers worked so I turned them on and had the headlight **** pulled. I went 2.5 miles and then everything came back on. The headlights, gear indicator light and radio. This just seems so strange ? I have no idea where to go with this problem ? In my opinion it is an electrical problem. But what is acting up or failing ?
Old Feb 26, 2014 | 07:24 AM
red89c4's Avatar
red89c4
you will need to inspect all of the grounds, do a search on here for C4 ground locations. good luck with your repairs.
Old Feb 26, 2014 | 08:59 AM
86 pace car's Avatar
86 pace car
Maybe it could be the courtesy lamp timer delay it solved a similiar problem on my 86
Old Feb 27, 2014 | 05:37 AM
HlhnEast's Avatar
HlhnEast
I would look at the headlight/dimmer switch or its ground. With the headlights out and all panel lighting that goes thru the switch out it would seem logical to me(not that my logic is all that sound sometimes). Where the radio fits in I dunno unless its aftermarket and the installer somehow tied it to the lighting circuit. When it happens again, pull the CTSY fuse and see if there is power across the blades. Check the headlight fuse socket the same way. If you have power there, I would pull the headlight switch to access the wiring harness and see if you have power in to the switch and it is coming out. I am thinking the panel lighting gets power thru the TAIL fuse as well so check it at the box.
Just a few ideas to start on.
Good luck!
Old Feb 27, 2014 | 11:00 PM
pcolt94's Avatar
pcolt94
Those are a lot of systems not to work for all to have a common ground. As a suggestion, I would look at any of the fuse boxes or fuse links under the hood. Seems like there might be a major voltage feed that might be loose, corroded and in bad shape.
Try turning the headlight on and pull, wiggle and inspect all you can. Look for anything in bad shape or suspicious. See if the lights or radio flicker when you pull on something.
Old Feb 28, 2014 | 05:46 AM
C4in mesa's Avatar
C4in mesa
My friend suggested my odd electrical problem might be a result of the underdrive pulley. I admit that there have been at times very strange issues but never anything that affected me being able to drive the car. My radio not working or the lights being dim and only for a matter of seconds. At a stop with everything running including the A/C as I recall this last happened. Saturday I will check out grounds and see if I find anything.
Old Feb 28, 2014 | 06:47 AM
hooked073's Avatar
hooked073
I agree with Hiln I would take a hard look at your head light switch.
Old Feb 28, 2014 | 09:32 AM
C4in mesa's Avatar
C4in mesa
I will check out the switch for sure. However I feel its unlikely to have much affect on the interior lights, radio, and hood lights. More likely a ground issue the fact it is intermittent makes me think that or my underdrive pulley.
To Odd electrical problem ?
