Temp too high
Old Mar 13, 2014 | 02:47 PM
DanielRicany's Avatar
DanielRicany
Default Temp too high
Hello, I have a 1985 Corvette with a Miniram, Flat Tappet ZZ409 cam, AFR 195 Heads, Hedman Long Tube 1 5/8" headers, 58mm Throttle body, 3.75s, Dynomax true dual exhaust, and a bunch of other miscellaneous modifications.
In my tune my cooling fan is set to come on at 92* C, which is about 198* F. Before I installed the AFR 195 heads, the temp used to go to 206* F, and start dropping down. Now it goes to 225* F and starts dropping down. But the fans are still coming on at 198*F.
Does anybody have any idea of whats going on?
Thanks!
Old Mar 13, 2014 | 04:00 PM
hooked073's Avatar
hooked073
fans do not control your temp stats do. What stat are you running. if you are sitting there ideling it takes awhile for the fans to pull enough air across the rad to cool the cooleant to bring the temps back down
Old Mar 13, 2014 | 04:01 PM
pcolt94's Avatar
pcolt94
I had a similar situation on an engine I rebuilt increasing the power some. It was more power and more heat was generated (my assumption). I ended up installing a larger radiator which helped control the temperature.
I'm sure there can be several other situations and answers.
Any chance the radiator needs a flush.
Old Mar 13, 2014 | 04:11 PM
DanielRicany
I flushed the whole system a few months back, and I've since added new coolant.
Old Mar 13, 2014 | 04:12 PM
DanielRicany
I think it may be due to the aluminum heads pushing out the heat faster and the heat being absorbed by the coolant faster than the old iron heads... Unless there is a problem with the thermostat?
It's a 195* stat I believe, it's a factory replacement.
hooked073's Avatar
hooked073
you are still well in the norm
Old Mar 13, 2014 | 04:13 PM
ynot d's Avatar
ynot d
Timing too far advanced?
Old Mar 13, 2014 | 04:14 PM
7d8's Avatar
7d8
I too just installed new 350/260hp in my 85 and it runs up to 225. Temp here in Florida is in the 70's. Been running the car for about 3 days now.
Old Mar 13, 2014 | 07:57 PM
DinoBob's Avatar
DinoBob
What? Fans don't control your temp?
Old Mar 14, 2014 | 02:32 AM
Cliff Harris's Avatar
Cliff Harris
Fans control the MAXIMUM temperature. That assumes that the radiator has the ability to get rid of the heat. That can be compromised by many factors.
The MINIMUM temperature is controlled by the thermostat.
Old Mar 14, 2014 | 02:39 AM
illenema's Avatar
illenema
If you had it re tuned, I bet its set to run leaner and will produce more power/heat.
To Temp too high
