Pulled the engine from the 84 yesterday. (pics)
Accessory drive is off in this pic, spark plugs and headers were off next, exhaust had been dropped already.
Here is the engine on its way up and out. Getting to the top two bolts on the bell housing was a real PETA and took a while with a wrench getting 1/32 of a turn at a time, the bottom four bolts are fairly accessible.
Bad news bears... cyl 1 has a head gasket leak. There was no coolant in the oil or oil in coolant when I drained fluids so I know its not bad, and it didn't run rough. In fact I only noticed once I put the engine at cyl 1 TDC when this little bit of milkshake started dripping out. Oh well only an extra $35 for a new head gasket and I have ARP head bolts so those should still be good.
This is as far as I got it last night, turns out I lost the bolts for my engine stand so I had to go pick more up this morning so I can start tearing down the engine for the cam swap. Also, the tire under the engine is only there in case my engine hoist decided to fail overnight, which it didn't. The tire was there just in case, it wasn't resting on it.
For those wondering, I am installing a Comp Cams 292H kit (lifters, chain and gears included) and a B&M 3000 stall torque converter along with new engine mounts, oil dipstick and removing the front spring to install the lowering kit. I already have 1.5 comp cams magnum rockers, hardened chromemoly pushrods and from the pics you should be able to tell those are not the stock heads or intake either. lol
After placing the new headgasket in position I installed the new cam and put the old timing chain and gear set on it because as it turns out, the new timing chain and gear set I got is way too big to fit under the timing cover, and since the timing cover hits the water pump I would have to replace a whole lot more to get that chain and gear set installed. I inspected the old chain and there wasn't a whole lot of stretching in it and the gears look great so I'm not too worried. I don't plan on drag racing the car more than once or twice a year so I think it should be fine. Timing marks are lined up.
This is how the engine is sitting now. I have to go pick up some thread sealant for the head bolts, not having enough thread sealant on the head bolts could have also been a possible cause for the coolant in cyl 1 so I'm going to make sure that the threads are covered enough on the head bolts this time.
More to come later! After getting the head torqued down comes the all important test of making sure the valves wont hit the pistons. I doubt the engine will go back in tonight, I still have to pull the front spring for lowering and want to do some cleanup in the engine bay while I have the room for it.
I just checked mine a couple days ago. 64cc, 2.08" intake, .504" lift, -10cc Probe pistons, zero deck, no head gasket and had plenty of room.
Any idea what size cam you had in it and what ratio rear end you are running?
Now would be a good time for a can of this.
Oh and if any of you were wondering how tall my engine is... here is a pic of it on a stand "assembled."
Speaking of height, do you have any pics of your car? The only one I can find is in your avatar.
I'm not 100% sure what I have. The car has had a lot of hands on it in the past. But its an '84 z51 auto, so it could be whatever came stock for the z51 auto. I could try to find some serial numbers or something, or when I get it running compare my mph to rpm with the TCC locked and see where it falls.
Yeah I cannot wait to fire this thing up and see and hear what the cam does to my engine.
Hurray for double roller timing chains! Wasn't difficult to install at all. Actually the hardest part about it was removing the old timing gear from the crankshaft, and that was only difficult because my puller decided to keep slipping off...
Lining up the timing marks and getting the chain to play nice wasn't nearly as taxing as I thought it would be.
I decided it would be best to go with the "0" cam timing key way vs the 4* either advanced or retarded. With my setup and it being a mostly street vehicle I didn't care to move the power band up or down in the RPM range more than the cam does on its own.
After I got the timing chain and gear set installed I moved onto cleaning up the front of the block so I could paint it. Don't worry, I didn't paint the timing cover or even clean it with it on the block. putting it on was just the best way to "mask" what sits behind the cover.
Woo fresh paint! You might be thinking to yourself, "That moron forgot to mask his intake manifold!" But actually that manifold is a spare, I'm using that one to hold the weight of the engine instead of my nice Trick Flow intake in case something decides to go wrong.
Tomorrow I will be cleaning up the engine bay and lowering the front end. Maybe even putting the engine back in!
In doing so I also found out that the power steering rack is puking fluid out of the pass side, a new one of those is getting added onto the list. Since I used rubber cement to glue the lowering bushings onto the spring I clamped that down and let it dry over night and installed the spring and reassembled the suspension the next day. After I installed the power steering rack I installed my brand new shiny B&M torque converter and then began the task of getting the engine back in its home. After wrestling with the engine and transmission for a bit I decided to put the engine mounts in the car and lower the engine down on top of them and that worked like a charm.
Wont be too much longer and it will be running again! Goal is to get it started Friday evening or Saturday morning since I really don't have time to work on it during the week.
I will for sure be posting how the car reacts to this cam and torque converter, and after the cam break in period I plan on putting it on a dyno.
