Im not sure he really has a problem after some of the post today I was hoping he would come back I would love to see what his temps are at a cruise of 50 pmh or so. This would tell a lot
You Want Cruise Temps Or Like Acceleration Temps At 50 Mph?
Well I replaced the Temperature Sending Unit to see if the gauge was misleading me. No change. Also I retarded the timing a little as someone I know suggested, no change. The numbers just climb so quickly almost like it doesn't have enough time to cool down. Also I should add that it doesn't drop when I pull over, it keeps climbing. I have to shut it off, wait a few seconds and start it up again. Then the temperature drops. It got to 240 and I shut it off.
I'm out of ideas. I think maybe it's not getting enough air flow through the radiator possibly? If it's not that then maybe it isn't circulating fast enough inside the motor.
"AFR thoroughly cleaned your cylinder heads prior to shipment. Your heads were washed in water soluble chemical agitation tank and blown out with high pressure air 3 to 4 times before they were boxed. However during some machining operations chips are packed and wedged into the water jacketing and occasionally come loose in transit. Keep in mind one chip the size of a dime breaks into hundreds of tiny chips and makes the situation appear much worse than it is in reality. It is not usually if you blow high pressure air into the water jacketing to see additional foreign debris, or chips finding their way out. AFR recommends that you thoroughly blow out your heads prior to installation."
Could you possibly have a partial obstruction? Did you use the recommended gaskets?
This may sound far fetched, however were you able to check the new head gasket you used when you installed the new heads. By checking I mean verifying the coolest holes are matche to both the block and the heads. It may sound unnecssary but if the holes in the gasket don't align with both head and block it would cause a problem like you described. Also, it is possible a gasket hole is missing. I had that happen to me once, it drove me crazy (no pun intended).
I blew them out as AFR suggested and I did not use the recommended gaskets from AFR. Instead, I used a Chevrolet Performance 10105117 gasket.
I did not check against the head. But it matched the block perfectly and had the same hole patterns as the stock gasket.
I called TPIS and they said that the Miniram has be redesigned and they no longer have that problem. Clay recommended that I try some better flowing thermostats, and he also said to make sure I'm getting the correct timing advance. I'm going to try to advance it a little more and see if it's better.
Bob at TPIS said that you have to raise the RPMs and then add coolant, then cap it off and release the throttle to properly fill the system. So I'm going to try that too.
you really need to see if you have combustion gasses going into the cooleant. get a pressure tester hook it up start the car watch the gauge if it starts to climb pretty fast and up past 5 lbs or so with out the engine getting hot you most likely have a problem. I sometimes will do this test on a hot engine that way if you have something expannding causeing you problems it will pick it up.
I did the test and I started at a little bit below 100*F coolant temp.
By the time it hit 150*F, I had 2 PSI on the gauge.
Im trying to find a hand out I used to give my students on using the Stant pressure tester to find gas in cooleant. Give me some time I know it should be on here somewhere
Here's what I'd do to figure out if you have air pockets, gut a thermostat & fill with coolant, rev it up while filling & watch the flow inside the radiator. It should look like a waterfall. Keep adding until it's full & put the cap on & drive it. That should get all the air out of it for test driving it.
Got some interesting information. I hotwired the auxiliary fan, and I started it up. First time around it went all the way up to 230*F, and came down to 195*F. Second cycle it went to 224*F and came down. Third time around it didn't go passed 200*F, it just stayed between 193*F - 196*F the whole time for about 15 minutes, until I shut it off. This was only at idle. And it never did this until I wired the auxiliary fan up, so maybe this will get me somewhere?
Gonna take it out in a few minutes and see how it does.
If this does anything it means you have something blocking air coming across the rad while you are driving it. At 30 plus mph more air is going to be pushed thru the rad then a fan could ever do
