Still overheating...
Old Mar 24, 2014 | 12:46 PM
DanielRicany's Avatar
DanielRicany
Default Still overheating...
Hey guys I have a 1985 Corvette. This problem all started after I installed brand new AFR 195 Eliminator Heads.
The car overheats when you drive it but when you pull over and let it idle it cools down. It could be sitting idling all day and have no problem cooling.
I just replaced the radiator with a performance radiator and the problem still persists. New thermostat, CTS, water pump, cooling system passes all pressure and vacuum tests and the engine passes compression tests. Also no coolant loss.
I'm out of ideas.
Thanks!
Old Mar 24, 2014 | 01:19 PM
GQ-ROD's Avatar
GQ-ROD
I'm out of ideas.
Thanks!
Check that you bled the coolant system properly, also check that you are not running too lean. Check your EGR system for proper operation.
Old Mar 24, 2014 | 01:23 PM
bjankuski's Avatar
bjankuski
Is your air dam installed under the car?
Old Mar 24, 2014 | 01:28 PM
c4cruiser's Avatar
c4cruiser
How did you "burp" the cooling system?
The best way is to raise the front of the car at least 12". Remove the radiator cap and start the engine. Let in run to allow the thermostat to open. You should see a drop in the coolant level at that point. Raise the RPM to about 1100-1200 and fill the radiator so that the coolant level is at the top of the filler neck. Reduce RPM's to idle and replace the cap.
Is the cap the correct pressure rating? Make sure the coolant in the overflow reservoir is at the correct line.
You also stated in another thread that you wanted the "best" AFR for your build. You need to get that done by your tuner. If the engine is too lean now, that would be a overheating issue. What's the base timing set at?
And as mentioned, do you have the lower airdam installed? That is needed to get air directed up to the radiator.
Old Mar 24, 2014 | 01:30 PM
DanielRicany
I bled the cooling system using an evacuator and fill tool from snap on. The AFR gauge reports 14.7:1 under normal driving conditions, EGR is gone and deleted from tune.
Yeah it's still there.
Old Mar 24, 2014 | 02:34 PM
don hall's Avatar
don hall
Cooling is basic... air flow and coolant flow.... interrupt one, or both,
and you will overheat. Since there is no loss of coolant, a head gasket leak is ruled out. Just a guess, but is the belt slipping on the pulley?
What are the temps?
Just the opposite of how it should work. At idle, the fans will operate when the programmed hot temp is reached. At speed, the air motion supplied by the dam should provide adequate cooling.
Old Mar 24, 2014 | 02:49 PM
don hall's Avatar
don hall
Another suggestion.... it is possible that the knock sensor has build-up around it, and slowing coolant motion.
If you haven't replaced the knock sensor (instructions in the link),
you might consider doing so, and use high pressure water injected
into the knock sensor hole to remove 'gunk'....
http://forums.corvetteforum.com/c4-t...ck-sensor.html
Just a normal flush will not remove the 'gunk' around the sensor.
Old Mar 24, 2014 | 03:03 PM
hooked073's Avatar
hooked073
do you do the pressure test like I suggested before. You have a classic symtoms of combustion in the cooleant. You need to test for this and a pressure test is a good way of doing this
Old Mar 24, 2014 | 03:09 PM
don hall's Avatar
don hall
If exhaust gases were present in the coolant, it would be due to a head gasket leak, and there would be increased pressure in the cooling system forcing coolant out. Since there is no loss of coolant, that would preclude exhaust gases from being in the system.
Old Mar 24, 2014 | 03:27 PM
bjankuski's Avatar
bjankuski
I'm out of ideas.
Thanks!
Stupid question but do you have the correct rotation water pump? Some SBC had opposite rotation water pumps and is there a chance that you put one of those pumps on by mistake? Are you sure there is not a defective water pump (Failed impeller) or failed T-stat.
Old Mar 24, 2014 | 03:29 PM
DanielRicany
Yeah also the hoses don't build up with pressure. You can still squeeze them.
But I have an update. I finally took it out on the highway, it doesn't happen at around 50 mph or higher. It cools fine. It seems to happen at around 30 mph or lower.
Old Mar 24, 2014 | 03:30 PM
DanielRicany
Well the thermostat is new and the belt is routed correctly. The previous owner had a shop install one before I got the car. A few people had suggested the water pump so far. But I should also add that when I rev the engine to about 2k - 3k RPMs, it sounds like someone put a baseball card in the spokes on a wheel of a bicycle. I thought it was coming from the AIR pump but I may be wrong.
Old Mar 24, 2014 | 03:32 PM
GQ-ROD's Avatar
GQ-ROD
Did you check to see if your fans are working?
You mentioned CTS, but is this the one that activates the fans? there is one for the fans, one to tell the ecu what temp the eng is, and a sensor for the dash guage.
Silly questions i know BUT you never know.
Old Mar 24, 2014 | 03:36 PM
DanielRicany
Yes the fans come on at about 194* F, the CTS reports about 10 degrees lower on the scanner compared to the digital dash going off the Temperature Sending Unit.
Old Mar 24, 2014 | 03:56 PM
GQ-ROD's Avatar
GQ-ROD
Ok good, as has been mentioned you may have to check your thermostat again, i had new thermostats i got at autozone go bad literally in one day, took it out and it was stuck closed. I also had a failsafe go bad in one day, ok it did do what it said it failed in the open position, but ONE day????? not good.
This happened to me more than once, so now i go right to the dealer of any car i have and just buy the brand specific dealer thermostat, yeah i pay the 16.00 but it's worth it to save me the grief of being stranded.
Old Mar 24, 2014 | 04:29 PM
hooked073's Avatar
hooked073
It is very possible to spit the cooleant into the recovery tank and not loose and noticabe amout of cooleant. Esp with the little amount he has driven the car. But now that he says it only happens at 30 mph that follows no real reason to me at this time
Old Mar 24, 2014 | 04:31 PM
hooked073's Avatar
hooked073
What are your temps at all points of operation this may help
To Still overheating...
Old Mar 24, 2014 | 04:35 PM
DanielRicany
When sitting in my driveway it will go up to 220 and come down to like 185.
When driving under 30 mph it keeps going, (237 was the highest so far), until I pull over and it comes down to around 185.
On the highway at 50 mph or more it goes to around 215 - 220 and comes back down.
Old Mar 24, 2014 | 04:59 PM
hooked073's Avatar
hooked073
is the 30 mph in stop and go traffic?
Old Mar 24, 2014 | 05:19 PM
DanielRicany
Yes. But if I come to a stop light it'll drop down. When I consistently have a load on it it climbs up.
Also someone I talked to said that my Temperature Sending Unit is placed in an area that is hotter than other areas. It's between Cylinder 1 and 3 on the drivers side in between the headers. Someone said I may get a hotter reading there than I would in a place next to the thermostat housing. Any input on that? Thanks!
