h36 error code
Old Mar 26, 2014 | 03:18 PM
1995Corvettelt1's Avatar
1995Corvettelt1
5th Gear
Default h36 error code
I know that the h36 code is the beloved opti, but the thing is a dealership replaced it less than 5,000 miles ago. They fixed it, i took it back cause it seemed like it misfired, they said it was an maf sensor, and that it was fixed it sat for a year as i went thru legal things. Went to drive it and it did the same thing so i lied to myself and said it was something else replaced fuel pump and both o2 sensors and then checked code and got h36 but its got like i said a brand new distributor and water pump so im not sure. i dont want to invest in a brand new distributor if you guys have any suggestions please let me know! thanks
Old Mar 26, 2014 | 04:08 PM
1995Corvettelt1
5th Gear
Not sure if i should do just cap and rotor or if there are other things i should check first.
Old Mar 26, 2014 | 04:33 PM
bassackwards's Avatar
bassackwards
Your check engine light on now? You will always have a code 36 until you either disconnect the battery for a short time or manually erase the code. H means history.
Cap and rotor have nothing to do with a code 36. I consider myself and opti expert now
Old Mar 26, 2014 | 04:46 PM
1995Corvettelt1
5th Gear
It is on, and its doing the misfire thing, and yeah the battery was disconnected while changing the fuel pump. What distributor do you recommend, im really trying to not go bankrupt on this lol
Old Mar 26, 2014 | 04:58 PM
bassackwards
I had no satisfaction with anything other than a real GM unit. I put 3 on my car before getting it to run right. A used OEM fixed me up. I put a cheap one on a Trans Am and it's already been replaced once and another on another Formula is about to be warrantied.
Stay away from Petris. I have some pics of his products floating around here.
You could also double check the wiring on the rt hand side of the intake down to the opti.
Old Mar 26, 2014 | 05:07 PM
1995Corvettelt1
5th Gear
Thanks for the info, i really appreciate it. And yeah ill be checking the wiring befor i dive into getting a distributor.
To h36 error code
