Bose amp capacitor question
Old Mar 29, 2014 | 02:36 PM
Tttiger's Avatar
Tttiger
Default Bose amp capacitor question
Calling all Bose techs...
I have Bose amps out of the car to replace the capacitors (they work well, just squealing a bit)
I've looked all over at different threads and find that different years have different amp configurations. I have an '89 which is the poster child for amps gone bad.
I know I have to replace the green and blue capacitors in the picture. The greens have leaked.
My question is; do I also replace the brown capacitors I have circled in blue? None of the threads I looked at were specific to my '89 amps and none said anything about those other caps.
I checked the numbers on the caps and find they're obsolete. If they should be replaced, what did you replace them with?
Old Mar 29, 2014 | 02:52 PM
Tttiger's Avatar
Tttiger
Here's a tidbit I found on-line:
"The 1989 Corvette is different from the 1988 and older Corvette Bose systems. The 1989 Bose amplifier design is not as reliable as the older amplifiers. This system can have four bad amplifiers."
Makes my day....
Old Mar 29, 2014 | 03:26 PM
RemS64's Avatar
RemS64
Cruising
I am not a Bose guru, but I am an electronics Technician. The Brown Caps you circled are Mylar and they rarely if ever go bad. The Blue and green caps are Electrolytic. They always go bad, even sitting on shelf.
Were it mine I would just replace the electrolytics.
Not sure this will fix your problem, but it can't hurt.
Ron
Old Mar 29, 2014 | 03:42 PM
pcolt94's Avatar
pcolt94
I have been repairs them for 10 years and done several write ups.
No, do not replace the regular capacitors, only the electrolytic green ones you have circled. Don’t bother with the big blue ones either which are 750 or 800 mfd. They don’t almost ever go bad and are hard to find the physical size also (regardless of what other tips say).
Do the 5 green ones and that should do it. The orange drops are probably OK and don’t leak or change value like the others. They are thallium capacitors and have seen them short in my electronics career but not in the Bose amps. I don’t know what value they are or the C number.
Don't mess up the lands, use a solder sucker or wick, easy on the heat.
Observe polarity, solder blobs and ESD.
Old Mar 29, 2014 | 03:43 PM
MotorCity_87_C4's Avatar
MotorCity_87_C4
I agree with RemS64, replace the electrolytics.
Old Mar 29, 2014 | 10:42 PM
Tttiger's Avatar
Tttiger
Thanks everyone for the tips!
I'll start with the green 5 and see what happens.
I'll follow up with a post.
Tttiger's Avatar
Tttiger
Old Mar 30, 2014 | 12:21 AM
mixalive's Avatar
mixalive
Digikey carries the correct values in the correct physical sizes. You can go up in voltage rating.
Old Mar 31, 2014 | 12:15 AM
Tttiger's Avatar
Tttiger
I live close to a Frys electronics so I went today and got the replacements for the 5 green caps, one 1mf, two 10mf and two 47mf (per amp). I did 3 of the 4 amps this evening and tested. Awesome! No more popping, hissing or whining. Great sound too! It was a quick easy fix. All 20 caps cost less than half of what it costs to have one amp repaired.
Old Mar 31, 2014 | 01:29 AM
ToniJ1960's Avatar
ToniJ1960
Electrolytics are the ones that are to be suspect. The others I have hardly ever seen be bad.
I would think theyre ceramic or possibly mylar, maybe poly. Thallium is new for me.
Old Mar 31, 2014 | 09:35 AM
tx75vette's Avatar
tx75vette
Thanks for the info Tttiger.....do you have the part # from Frys for the caps? I need to do this to my 89.
Old Mar 31, 2014 | 09:44 AM
RemS64's Avatar
RemS64
Cruising
Thallium is new to me too, I have been in electronics business for 45 years and a Hobbiest b4 that. But alas Maybe you can teach an old dog new tricks.
Ron
Old Mar 31, 2014 | 10:11 AM
Joe C's Avatar
Joe C
Ron
Old Mar 31, 2014 | 05:29 PM
skyhawk50's Avatar
skyhawk50
I've had Bose issues on just about every C4 I've owned. My fix is easy. BOSE in the trash. Hello UPS driver with my new aftermarket unit and speakers.
Old Mar 31, 2014 | 11:40 PM
Tttiger's Avatar
Tttiger
The Fry's part numbers: All are NTE brand
1 mf-50 volt - NTE-VHT1M50 - Fry's SKU 1005453 - Need 4 (1 per amp) - $1.99 ea
10 mf-50 volt - NTE-VHT10M50 - Fry's SKU 1005443 - Need 8 (2 per amp) - $1.09 ea
47 mf-50 volt - NTE-VHT47M50 - Fry's SKU 1005583 - Need 8 (2 per map) - $1.09 ea
Old Apr 1, 2014 | 10:50 AM
tx75vette's Avatar
tx75vette
Thanks for all the info Tttiger
Will give this a try on my 89 this weekend.
Old Apr 1, 2014 | 11:35 AM
volkswagens-for-life's Avatar
Super awsome info in this thread Great for all future Bose issues!
To Bose amp capacitor question
Old Apr 1, 2014 | 04:56 PM
Deavis's Avatar
Deavis
Quick someone must sticky this one
Old Apr 3, 2014 | 09:54 AM
tx75vette's Avatar
tx75vette
Well I got a chance to go down to fry's and pick up some capacitors for the amps.
Did the repair to the rear speakers and no more popping or screeching coming from the rear speakers.
Repair was pretty simple after getting the speakers out.
A big thanks to all the electronic gurus that contributed to this thread.
Now off to the front speakers.
Old Jun 3, 2021 | 05:50 PM
Spike7's Avatar
Spike7
1st Gear
Tantalum! is the correct type
Not Thallium
