Need help with TB disassembly.
Old Jul 17, 2002 | 04:03 PM
champs_97's Avatar
champs_97
Default Need help with TB disassembly.
I'm cleaning my TB tonight because while I was doing the TB bypass the other day I notice that it was real dirty. How do you take it apart? Do you need to replace the gasket? Any tricks/do's/don'ts? 85' L98
Old Jul 18, 2002 | 12:19 AM
gbody5's Avatar
gbody5
Default Re: Need help with TB disassembly. (tntcorvette)
Gasket set is cheap and you can clean it better by taking it apart, but not required as long as you don't tear up the gasket that goes between the TB and the plenum while removing.
If it has high miles it may not hurt to replace all the gaskets.
