Car Tune
This sounds more like a fuel problem. Suggest you get a fuel pressure gauge and hook it up. Then tape the gauge to your windshield so you can read the pressure. Then take it out for a run and watch were the pressure is when your cruising.
What's probably happening is when you are warmed up, or after the first five minutes, the stumbling is because you are running the wrong injectors. Your injector off sets are designed for 24 lb injectors, and your MAF tables are also designed for that.
So, in closed loop, the ECM will correct, or try to correct the AFR, when you give it gas, the ECM does not have enough time to respond and you get a stumble. This is probably because of one of the following reasons: When you have a higher flow rate, you don't need as long of an injector pulse, when you have a lower flow rate, you need a longer injector pulse. So you are running on a short injector pulse on a low flow rate, meaning you in theory should be running lean. As the ECM corrects for this under a stable condition, as soon as you move out of that range, the ECM is not expecting that change. So, you could be stumbling because of a misfire, or stumbling because of spark knock with timing retard.
Now you can see that when you are cold for the first five minutes it doesn't do this, well that is because you have longer injector pulses. This would occur because you are already rich, so as it leans out when you give it gas, you are still within the okay zone in terms of throttle response and performance.
That's what I think your main problem is coming from. But since you also have a different camshaft in there I think that is also related.
Just to recap: idles like a dream and accelerates nice..... but when cruising ..... be prepared for some turbulance folks.
If you've cammed the car you need to find a competent tuner that can provide what you need. 85 tuners are far and few, so be careful. Better would be to update to the 86 thru 89 7165 for faster processor speed and more options, but for some this is a challenge.
Good luck!
Good luck!
Honestly, that good ole made in America diaphragm is superior to any foreign replacement, so you should be good to go!
Oh, almost forgot, I like the www.tpis.com adjustable regulator cap myself.
look at replacing the 21 pound injectors with 24's. You should check the specifications on the crate motor's cam and compare it to the stock 85.85 and 86 cams are the same by my records (vader86)
202/206 @050
Lift with 1.5 R 403/415
Lobe Separation 114.5
If your cam is much different, a tune may be required.
202/206 @050
If they are similar, its likely not to need much, but between that and the injectors it may warrant a tweak to get it to run right all the time.
Cast iron crankshaft
LT1/LT4 powdered metal connecting rods
Cast pistons (dished)
Hydraulic flat tappet cam (.383''/.401'' Lift, 194 / 202 Duration @ .050'', and 112° lobe separation)
Cast iron cylinder heads with 76cc chambers
8.5:1 compression ratio
Block is compatible with left or right side oil dipstick (Requires Plug for Unused Side - Plugs are Included)
4-quart oil pan
Timing tabs for a 6-3/4'' or an 8'' balancer
Recommended spark plug: Accel #111-0574-4 or any spark plug with 14mm .460'' reach, 5/8'' hex, tapered seat, projected tip
It's an aftermarket part that not a lot of people need. It comes with a Miniram Intake Manifold too.
You can get one here. https://tpis.com/parts/view/16
Your codes may be researched here:
http://www.chevythunder.com/Flow%20c...roubleshooting Flow Chart Pages
