High Beam Actuation Linkage
Old Apr 8, 2014 | 11:23 PM
wschmidt's Avatar
wschmidt
Default High Beam Actuation Linkage
Does anyone have a good picture or schematic of how the high beam switch actuation linkage is set up on a 93 LT1 coupe? My high beams have never worked at the lever and I had the column dropped to work on my LCD cluster so I figured I would check out the high beam situation while I was in there. The switch works if I push on it down on the column, but I cannot actuate it with the lever like I should be able to. There is some linkage loose up by the wheel and a part fell out so I have no idea if there is something broken or just out of place or even how to put it back together. The FSM doesnt appear to show this detail. Thanks.
Old Apr 8, 2014 | 11:28 PM
vetteoz's Avatar
vetteoz
http://www.crankshaftcoalition.com/w...ck_Rebuild.pdf
Old Apr 9, 2014 | 10:07 AM
wschmidt's Avatar
wschmidt
Awesome, thank you very much. You can find anything on the internet these days. Looks like I am taking apart my steering wheel. I wonder how many Mechanical Engineers they let loose on that design
To High Beam Actuation Linkage
