700-R4 rebuild
Old Jul 18, 2002 | 05:50 AM
dppeaden's Avatar
dppeaden
Default 700-R4 rebuild
My 700-R4 kicked the bucket. was wondering what mods you have done. It has to be puled any way so might as well have some fun while I'm at it.
Save the Wave. :cheers:
Old Jul 18, 2002 | 08:27 AM
ski_dwn_it's Avatar
0ski_dwn_it
Former Vendor
Default Re: 700-R4 rebuild (dppeaden)
make sure you get it beefed up by someone that really knows trannies. Don't just go stock, especially if you are gonna start modding. It will be a short life if you do.
Old Jul 18, 2002 | 09:42 AM
NHVett's Avatar
NHVett
Cruise-In I Veteran
Cruise-In II Veteran
Default Check these guys out
http://www.transmissioncenter.net
Old Jul 18, 2002 | 10:56 AM
65Z01's Avatar
65Z01
Last week I had mine rebuilt by Grant Transmissions in CT. I don't think he used realy heavy duty components as we discussed my needs and I told him I was now at about 300hp and would go to 350-375hp eventually.
I had a TransGo shift kit installed, the shift points raised and a 2,000rpm TC installed.
The result was a very crisp shift (chirps the tires easily on 1-2 shift) and a gain of 0.3sec off my ET at the strip. Also my short time came down nearly 0.1sec.
Old Jul 18, 2002 | 04:04 PM
BLUE ONE's Avatar
BLUE ONE
Default Re: 700-R4 rebuild (65Z01)
So what are your new times and mph ?:)
Did you get your trans done because it failed, or because you don't want it to in the future. :D
Cheers Mark
Old Jul 19, 2002 | 08:59 AM
PTz-92-LT1's Avatar
PTz-92-LT1
Default Re: 700-R4 rebuild (BLUE ONE)
Three suggestions as a start:
1) Heavy duty torque converter
2) Upgrade to the 9 clutch 2-3 clutch pack
3) Shift kit.
Old Jul 19, 2002 | 01:47 PM
Mojo's Avatar
Mojo
Default Re: 700-R4 rebuild (PTz-92-LT1)
Personally, I don't like the 9 clutch 2-3 pack. Everything is thinner, and thus more susceptible to damage from heat. I'd go with a trans-go kit as well.
Old Jul 19, 2002 | 02:06 PM
65Z01's Avatar
65Z01
Mark, I had an oil leak at the rear main seal that would have cost over $500 to fix (local Chevy dealer). Also I wanted a shift kit and raised shift points so I decided to have a good tranny shop do the total job. Vic'89 mentioned a the shop (Grant Transmissions) in CT that had done work for JD 383.
During inspection Grant found clutch flakes in the filter and, with other symptoms suggested a rebuild. Since part of the rebuild cost was dropping the tranny, it offset the cost of the rear main seal install, so I went ahead with it.
The higher stall TC was a last minute decision based on a conversation with a Forum member who was getting very good short times from his '85 Vette with a 2,000rpm stock TC on street tires.
Bottom line I paid about $500/0.1sec gain and got my A4 with over 110,000miles on the clock rebuilt along with a major oil leak fixed. Not a bad deal indeed.
My best time Sat. during the CC eliminations was 13.21sec at 102.4mph; that was in high 70s weather with a 29.88 baro lanching from about 1,100rpm with a weight of 3350lbs.
Old Jul 19, 2002 | 04:28 PM
J Z06's Avatar
J Z06
Jim,
Just an FYI ;) It is GRAN TRANS Just in case these guys are trying to contact Him(it's funny, because the guy you want to speak to IS GRANT).
Just an update. Once more, they do a terrific job.
To 700-R4 rebuild
